Baileigh RDB-175 tube bender - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 01-08-2009, 11:30 AM   #1 (permalink)
Fabrication Machines
BAILEIGH INC.'s Avatar
Member # 116406
Baileigh RDB-175
In stock, ready to ship.
Drop on tooling with over 2,200 die sets available for our benders.
Easy to read degree indicator with auto stop.
Fast ratcheting counter die adjustment for quick tooling changes.
Foot pedals for hands free operation.
9" Center Line Radius capacity
The RDB-175 pipe bender is a powerful machine capable of bending 2" Schedule 40 pipe and up to 2-1/2" tubing with a wall thickness of .120" mild steel. This style of bender (RDB-150) was introduced to the market by Baileigh Industrial in 2002 and now has thousands in the field working flawlessly every day. These benders easily bend 2 times the outside diameter depending on the wall thickness of the material. This model is a high speed version that bends 180 degrees in 12 seconds without stopping and returns at almost 300% of the bend rate. Accuracy is true because the degree of bend is measured from the die head instead of cylinder placement like other models on the market.
Mild Steel Pipe (Schedule 40) 2"
Aluminum Pipe (Schedule 40) 2"
Stainless Steel Pipe (Schedule 40) 1.5"
Mild Steel Round Tube (Wall) 2.5" (.125)
Aluminum Round Tube (Wall) 2.5" (.156)
Stainless Steel Round Tube (Wall) 2.375" (.125)
Chromolly Round Tube (Wall) 2" (.125)
Mild Steel Solid Rod 1.25"
Mild Steel Square Tube (Wall) 2" (.125)
Minimum OD .25"
Maximum Speed to 180 Degrees 12 Seconds
Maximum Center Line Radius (CLR) 9"
Minimum CLR .5"
Power Requirements 110V
Weight (Lbs.) 630
If you have any questions, please reply to this thread, give me a call or shoot me a PM.
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
www.baileighindustrial.com
920-482-3220
BAILEIGH INC. is offline   Reply With Quote
