Fabrication Machines
Member # 116406
NEW!! Baileigh RDB-050 tube bender, massive capacity, 3 speeds (check out the video)
![]() Baileigh RDB-050 Baileigh RDB-050 Tube Bender, 3 speeds, Large Capacity Tubing and Pipe Benders - YouTube The RDB-050 tube bender makes the other benders out there look like baby toys. There are many advantages to the RDB-50 over other manual benders on the market.
Baileigh RDB-050 Tube Bender, 3 speeds, Large Capacity Tubing and Pipe Benders - YouTube Baileigh RDB-050 Tube Bender Bending 2.5" x .120" Wall Mild Steel Tube 180 Degrees 2 Minutes 35 Sec - YouTube Baileigh RDB-050 Tube Bender Bending 2" x .120" Wall Chromolly Tube 180 Degrees 2 Minutes 40 Sec - YouTube ![]() Baileigh Industrial’s newest bender, the RDB-050, was designed from the ground up to deliver world class bend quality in an affordable package. This unit is aimed squarely at the serious home fabricator who may not be able to justify a larger hydraulic or programmable bender but still wants the quality and performance Baileigh Industrial is famous for. This revolutionary new design incorporates features previously seen only on much more expensive benders. Heavy duty bushings incorporated at all wear points for incredible service life and increased bend capacity. This is a bender for life! Three speed operation makes quick work of any bending job. Simply change pin location to adjust the amount of movement per “pull” (4, 8, or 12 deg.) – no confusing or time wasting disassembly required. For very light weight materials the operator can bend in one smooth pull all the way to 200 deg. This new leverage action along with an incredibly rigid framework allows for huge bend capacity – up to 2 1/2” OD (.120” wall) Mild Steel or 2” OD (.120” wall) Chromolly Tubing. A simple anti-spring back mechanism assures precise bend control and increased operator safety. At no time does the operator have to “hold” the arm in place and be subjected to dangerous backlash, an important consideration when bending the likes of Chromolly. Tooling changeover is fast and easy as no disassembly of the machine is necessary. Simply pull a few pins and slide in the new tooling – it’s that easy! The whole process can be accomplished in a matter of seconds. Once the part is completed simply slide the finished piece out of the machine. Our innovative design eliminates the need to disassemble the unit or remove tooling to release your work piece making the bend process clean and simple. Round tube tooling is available for either 90 or 180 degree bends and incorporates the same replaceable aluminum/bronze counter die inserts that Baileigh Industrial is famous for. Hook arm inserts for varying tube sizes assist with fast tooling changes. True to form, our tooling remains the best in the industry. The RDB-050 bender kit comes complete with the stand, handle and degree dial included. Simply add your desired tooling sizes and you can be up and bending in no time. It is UPS shippable to keep freight charges reasonable. If you would like a quote, reply to this thread, shoot us a PM or call your Baileigh Rep for more details ![]() ![]()
Shane Henderson Baileigh Industrial shenderson@baileighindustrial.com www.baileighindustrial.com 920-482-3220 |
Member # 116735
I saw it at the Wisconsin Racers Expo in West Bend and all I can say is WOW! Now I really wish I had waited before buying my JD bender last fall - I will probably have to sell it and get this one. So much easier to change over dies and very little effort to do even 2" Chromolly. The biggest thing is the bend quality - no flat radius bends! This thing looks way overbuilt for the money. Serious quality there. This thing is sweet!
#5 (permalink) | |
Member # 116406
Thanks!
Member # 116406
Member # 116406
I sent you a private message with your quote.
Member # 130484
Price on bender and 1 3/4", 1 1/2", and 1" die shipped to 98596? Could you break down the pricing on the dies?
52 Willy's Wagon TBI 350, NP 435, Jed's 203-205 doubler,NWF Cable Shifter, HP Dana 60 Front/spooled, FF 14 Bolt Rear/Detriot, 5.13 gears, Full Hydro, One Link Front and Rear w/ 2.5 x 18" SAW's 39.5 Boggers on DIY Beadlocks |
#10 (permalink) | |
Member # 116406
Thanks!
Member # 116735
Dude! I need a quote on the bender and a full die package. Got rid of the JD2 and need to pick one of these up. I can pick it up so don't worry about the shipping. Any chance on getting one before June?
#12 (permalink) |
Member # 13880
Price on bender and 1 3/4", 1 1/2", and 1" die shipped to 98277.
84runner with tons,r151,duals with 4.7s in the rear, a little tube and some tenderized sheetmetal. [URL=www.lucky13offroad.com/phpbb2]Lucky13[/URL] [URL=http://www.bluehost.com/track/Luckyone/text1]CLICK HERE TO SIGN UP FOR BLUEHOST.COM NOW[/URL] |
#13 (permalink) | |
Member # 116406
PM sent! Thanks!
#14 (permalink) | |
Member # 116406
June 1st is a "ball park" date of when these will be ready. Didn't I see you at the Racers Expo a couple weeks ago?
#15 (permalink) |
Member # 12932
quote for bender plus 1" & 1.75" die to 98208 please,
Thank you
1987 TT Samurai 16v Yj 4.16:1 tcase 4.57 diffs 32" BFG MT Shrock bumpers and bedliner everywhere. |
#21 (permalink) |
Member # 581
Could you quote shipped to 80487 biz address? Looking for the break-down for a 1 inch square, 1 inch round tube, 1.75 tube and a 1.5 X1.5 square die. Can it be upgraded to hydro down the road?
Thanks, Peter
87' FJ-60, 383, SOA w/OME's, Sm465/Atlas 5.0, Dana 60, Corp 14, locked, cage, some 39's. FJ-40 on the way. |
#22 (permalink) | |
Member # 116406
Thanks!
#23 (permalink) |
Member # 116406
#24 (permalink) |
Member # 116406
#25 (permalink) |
Member # 116406
PM sent!
Thanks!
