"New" Portaband Modular Mounting System - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 09-23-2009, 11:13 PM   #1 (permalink)
Swag Off Road's Avatar
Member # 120418
This "NEW" Portaband modular mounting system is compatible with all Dewalt and Milwaukee deep throat portable band saws.
Installation is straight forward, remove the foot guard mounting screws and install the ¼” thick lightweight 6061 aluminum mounting plate. This mounting plate weighs less than a pound and will reduce user fatigue when the portaband is used as it was originally intended for......being portable.
To convert your portaband into a vertical band saw, insert the saw into the table mounted band saw bracket, and tighten the 5/16” thumb screw
….simple as that. You now have a saw that performs two functions, a portable band saw and a vertical band saw that does not require any tools to switch between the two functions. The 12” wide ¼” thick table mounted band saw bracket is laser cut and formed on a CNC press break, It has 4 holes on the bottom so it can be securely attached to your work bench.
In this kit I provide all necessary hardware to attach a Dewalt or Milwaukee
deep throat portaband as well as all related fasteners to attach the steel bracket to your work bench.
$84.95.
Click here to view Youtube Demo.
YouTube - Milwaukee & Dewalt Portaband Modular Mounting System @ swagoffroad.com
Just released.
Bolt on Portaband miter gauge attachment.
Accepts the industry standard 3/4' x 3/8' miter gauge slide, and can be bolted on the right of left hand side of either Portaband table I sell.
Helps keep your strait cuts strait and your miter cuts repeatable & consistent.
If you purchased a Portaband table from me in the past and your table does not have two mounting holes on the side your will need to drill (2) 3/8" holes, per side.
Take a look at the attached YouTube video.
YouTube - Swagoffroad.com Miter Gauge Attachmet For Swag Portaband Tables.mp4
Thanks Troy
Swagoffroad.com
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on Facebook
Swag Off Road is offline   Reply With Quote
Old 09-25-2009, 01:10 AM   #2 (permalink)
Member # 138549
I like it too bad I just ordered the other style. Will you be making this one so it can be wall mounted like the old style?
reedwesd is offline   Reply With Quote
Old 09-25-2009, 09:33 AM   #3 (permalink)
Member # 120418
I don't have plans to make this version wall mounted.
Troy
Swagoffroad.com
Old 10-19-2009, 10:19 AM   #4 (permalink)
Member # 120418
Thanks for the order guys. Let me know if you have any questions.
Thanks Troy
Swagoffroad.com
Old 11-10-2009, 12:17 AM   #5 (permalink)
Member # 120418
Thanks again for the order guys.
Troy
Swagoffroad.com
Old 11-10-2009, 01:52 AM   #6 (permalink)
vbtj's Avatar
Member # 20204
Do you have these in stock and ready to go for a Milwaukee?
vbtj is offline   Reply With Quote
Old 11-10-2009, 09:36 AM   #7 (permalink)
Member # 120418
I do. I just got a new run of 40 parts sitting on my shelf.
Swagoffroad.com
Old 12-04-2009, 06:35 PM   #8 (permalink)
vbtj's Avatar
Member # 20204
O.k. I'm ready to buy one you got them in stock still?
Old 12-04-2009, 08:15 PM   #9 (permalink)
brokenparts's Avatar
Member # 71152
Send a message via AIM to brokenparts Send a message via MSN to brokenparts Send a message via Yahoo to brokenparts
any idea if the 28volt (battery operated) will fit?
I am offended by reality all the time.
My 1 ton fj60 build:
/forum/toyota-land-cruiser/708363-fj60-build.html
brokenparts is offline   Reply With Quote
Old 12-06-2009, 04:53 PM   #10 (permalink)
Member # 120418
I have plenty in stock.
Thanks again for the order.
Troy
Swagoffroad.com
Old 12-06-2009, 04:54 PM   #11 (permalink)
Member # 120418
They sure do.
Troy
Swagoffroad.com
Old 12-07-2009, 04:16 PM   #12 (permalink)
Member # 71152
Can I save a couple bucks on shipping and just pick the "modular" version up? I'm in Portland/Hillsboro.
http://www.pirate4x4.com/forum/showthread.php?t=708363
Old 12-07-2009, 04:47 PM   #13 (permalink)
Member # 120418
Feel free to swing on by and save on shipping.
Troy
Swagoffroad.com
Old 12-07-2009, 07:10 PM   #14 (permalink)
Member # 71152
right on dude... I just hit ya back with a PM.
Old 12-12-2009, 06:03 PM   #15 (permalink)
Member # 69305
Got mine yesterday and mounted to my welding table. I like.
Rich
TTF Rig In Apple Valley
OlMan is offline   Reply With Quote
Old 12-19-2009, 09:34 PM   #16 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
ever thought about making one so you could make it into a horizontal bandsaw too? seems like a simple hinge and a 2nd 'modular table with a clamp' might work out real well...
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 12-20-2009, 01:03 PM   #17 (permalink)
Newbie
Member # 147565
i just got one of these from troy .... its a slick setup and makes the porta band get used more ! i was contemplating a big band saw but this will do just fine for my little jobs
thanks troy for the good product and fast shippin !
www.tedsfabrication.com
tedsfab is offline   Reply With Quote
Old 12-20-2009, 08:11 PM   #18 (permalink)
vbtj's Avatar
Member # 20204
Got mine Friday and played around with it and for see it getting used a ton. Thanks for nice product at a reasonable price.
Old 12-31-2009, 02:27 PM   #19 (permalink)
Member # 120418
Thanks for the great feed back guys.
I have plenty of these Modular Portaband Stands in stock.
Troy
Swagoffroad.com
Old 02-01-2010, 10:26 PM   #20 (permalink)
Member # 120418
Thanks for the orders guys. Let me know how the Portaband tables are working out for you.
Troy
Swagoffroad.com
Old 02-01-2010, 10:46 PM   #21 (permalink)
vbtj's Avatar
Member # 20204
Using mine like crazy definetly worth the money.
Old 02-08-2010, 04:39 PM   #22 (permalink)
Member # 153297
I just ordered mine tonight. I know that this tool will get a lot of use.
baja540 is offline   Reply With Quote
Old 02-10-2010, 11:21 PM   #23 (permalink)
jnau99's Avatar
Member # 18907
95% of all my tabs were made on one of these "I'm cheap". Works great and would have paid for itself.
Thanks Troy.
jnau99 is offline   Reply With Quote
Old 02-24-2010, 10:30 AM   #24 (permalink)
Member # 120418
Thanks again for all the orders guys.
Troy
Swagoffroad.com
Old 02-24-2010, 08:43 PM   #25 (permalink)
Member # 71152
Mine works great... I'm happy with it.
