**NEW BTA BULLET 2x2 and 2x3 modular plasma systems**
Our new Bullet CNC Plasma table is screaming fast and smooth. Check out these specs!!
Buy it here! http://www.bulltear.com/catalog/product_info.php?products_id=241 Support forum here http://www.bulltear.com/forums/viewforum.php?f=93 Rapid capability of 1500ipm easily modified in software Portable Dual X drive motors Single Y drive motor Full Z axis with 5"s of travel with Z touch and cut micro switch All aluminum gantry parts are CNC machined Hardened V rail with wipers and oil wicking billet wheel covers 2"x2" boxed steel frame Capable of horizontal and vertical cutting Full support and online support forum Comes crated and complete! Everything you need to make CNC cut parts minus PC and plasma cutter DTHC option now available ![]() What makes this table so fast and accurate is that it uses the latest motion control hardware capable of morphing from micro step to full step without delay and with supreme accuracy. This means we have a very very fast rapid move and equally as fast feed rates. We do ot use limit switches on our tables due to the possible installation error or switch error that may cause crash damage to your machine. We instead use a gear rack tailored to the travel of the machine so if you over travel the gear comes off the rack and the machine slides top a stop against our limit travels with zero damage.
Industrial Quality CNC machines at a Hobby Price! USA Quality is job #1 We build CNC plasma tables, click me .................................................. .........![]() American Motors Engine HERE!! 1-651-257-7917 |
PMs returned and tables sold!
Rock and roll
PM returned
We offer a free Z axis, free software, comes assembled and free torch holder. Our little tables are the fastest in the world right now and are capable of cutting 3" thick to 26 gauge. Check the pricing on comparable systems.
Member # 13688
I ordered mine 2 1/2 weeks ago...no table yet and has not shipped. They ran into some problems i guess. Expected to ship next week. Ships truck.
PAC Racing Springs-Warn-BeCool-Lucas Oil-FK Rod Ends [url]http://savethehammers.org/sth/[/url] |
We are all set and shipping all current orders on tuesday. We are streamlining our operation so we arent going to be out more than a week from the time you place the order to the time it ships.
We offer these items on the 2x2 and 2x3 1. Free Z axis 2. Free torch holder 3. Free CAD (lifetime liscense) 4. Free Jog remote control Our 2x2 and 3x2 are the fastest of the smaller machines and have the best user interface available. These machines use open source software so your never left in the dust. They are also complete when shipped and everything is included so you dont get dinged on buying extras just to get yourmachine running. We are cutting with one at 500ipm right now and it doesnt even squint. Do the math, run the numbers and make an informed decision if your looking at a small CNC plasma table...nothing comes remotely close.
#12 (permalink) |
Absolutely! The height sensor is already wired in and ready for DTHC. Their are several versions of DTHC control out there and it can be added without any additional modifications to the table. This was a consideration - to allow users to choose their DTHC. Of course we can offer a DTHC control that will allow 500+IPM feeds with the table but the price goes up $600.
These tables come standard with auto pierce height control. The Z axis rapids down and touches off the material, rapids up to pierce height then feeds to cut height and this motion is repeated with every new pierce or start of new cut. This extends consumables many times when compared to a set by hand method and the operator only has to push a button. This will lead to better cut quality and DTHC will lead to the best cut quality possible without going to a Hydef system.
#13 (permalink) |
Member # 145912
Very nice....I'm impressed that you have an entry level machine with pierce height control features. You are correct that it will dramatically increase consumable life as well as cut quality in comparison to machines without an auto pierce height control.
Jim |
#15 (permalink) |
All our 3x2 tables ship fully assembled. 1/2 hour from uncrating and you can be cutting! Post up when you get it running!
#18 (permalink) |
Member # 13688
have it, works great. there was a little fiddling at first, but im sure Bulltear has that resolved, as i think i had one of the earliest units. The problem was in instructions in setting up the software were inadequate, not the physical machine. pm me if you want to chat.
the z control is the biggest selling point over the torchmate....it will move up to a rapid height between pierces to keep clear of tipped parts...as well as set torch height for each cut. on long pieces, you still have to make sure the part is perfectly level. i plan on adding torch height control based on arc voltage in the near future so this is not as critical.
#19 (permalink) |
playinwithit
Member # 97574
THIS is a huge asset that you ONLY will appreciate if you have it! I didn't have my Bulltear 4x4 settings high enough at first, and almost screwed up a 34" ships wheel sign that took me 10 minutes to redial the position of the table in because it drug the sheet out of place. Too high and you waste time, too low and you waste time and more than likely scrapped material.
Playin' with my Willys buggy build |
#20 (permalink) |
More Bullet's sold!
#21 (permalink) |
More Bullets shot out from our production facility. Thanks for the orders and be on the lookout for future upgrades!
#22 (permalink) |
Rock and Roll
#23 (permalink) |
Bunch of systems out there cutting away!
#24 (permalink) |
Lots of these out there and lots and lots of very happy campers!
#25 (permalink) |
New dthc option available!!!!!
