New Benchtop Press Brake @ Trick-Tools - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 09-21-2010, 03:26 PM   #1 (permalink)
Trick-Tools.com's Avatar
Member # 32822
Hey guys, some of you who are on our email newsletter may have already saw this, but I wanted to put it out there so everyone could check it out.
This is a new benchtop press brake we're carrying. This compact benchtop press brake is the perfect solution for the fabricator needing to bend small sections of sheet metal and plate steel. Utilizing a common 20 ton bottle jack, this press requires no outside power source or specialized pumps. Ideal for making suspension and body support brackets. With its relatively small footprint this press is also a perfect fit for those with limited working space. And with the optional 4-sided V-die made from 4140 tool steel, tight radius bends can be made in lighter weight materials. Videos available here!
Features:
  • Easy to use design, uses standard bottle jack
  • Heavy 1/4" and 3/8" plate steel construction
  • Powder coated frame
  • 1/2" thick tool steel punch
  • Pre-drilled bench mounting holes
  • Includes jack handle (jack not included)
  • Self contained spring return
  • Made in the USA!
Capacities:
  • 20 tons maximum
  • 10" in 1/4" mild steel
  • 9" in 5/16" mild steel
  • 8" in 3/8" mild steel
  • 4" in 1/2" mild steel
  • 2" in 5/8" mild steel
Specs:
  • 90º Maximum bend angle
  • 2" minimum distance between 45º bends
  • 2" minimum distance from edge of material
  • Dimensions: 28" x 14" x 7.5"
The press sells for $379.00. The optional 4140 tool steel 4 sided V-die for thin material is $149.95. They are 80lbs and can ship UPS. We've got several in stock for same-day shipping!
See it on our website here!
Christian Huffman
Trick Tools / Pirate 4x4 Sales
877-826-7268 Ext. 105
Christian@trick-tools.com
Trick-Tools.com
Shoot me a PM with your address for a Free Catalog!
Trick-Tools.com is offline   Reply With Quote
