Chemical Trickster
Member # 45111
Black Friday Promo - CHASSIS SAVER™ Rust Preventive Underbody Coating - 2 for 1 Sale!
![]() 2 for 1 CHASSIS SAVER™ Sale 3 Days Only - Friday 11/26 thru Sunday 11/28 Available Only Online - Not Available in Stores For anyone not familiar with this product, CHASSIS SAVER™ is a direct replacement for POR-15 at up to 45% lower cost. We have been manufacturing CHASSIS SAVER™ for almost 20 years and it has been proven under the harshest conditions. In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance facilities use CHASSIS SAVER™ for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance. Starting Friday 11/26/10 at 12:01 AM thru Sunday 11/28/10 at Midnight all CHASSIS SAVER™ Quarts and Gallons will be sold 2 for 1 Buy 1 Quart CHASSIS SAVER™ Get 1 Quart FREE - Coupon Code: CSQT-B1G1F (1 Quart price $34.75) Choose 2 of same color or 2 different colors Buy 1 Gallon CHASSIS SAVER™ Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F (1 Gallon price $97.50) Choose 2 of same color or 2 different colors ************************************************** ************************************** To get the free item, YOU MUST PUT 2 ITEMS IN YOUR SHOPPING CART BEFORE APPLYING THE COUPON CODES ************************************************** ************************************** Standard UPS shipping rates apply - $9.00 for 2 Quarts, $15.00 for 2 Gallons Place Orders Here @ www.monstaliner.com Colors/Finishes available are as follows: UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade synthetic, acrylic or urethane enamel. UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoating is not needed unless change of color is desired. UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors. UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Note: Use of gloss black is recommended over Satin Black if you know ahead of time you are going to topcoat. ![]() Note: Chassis Saver™ can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep. After 24 hours scuff sanding is required. Please see Technical Data Bulletin link below for complete directions on surface preparation and application. CHASSIS SAVER™ Tech Bulletin CHASSIS SAVER™ Material Safety Data Sheet ------------------------------------------------------------------ Further Details: The Coupon Codes above ARE NOT COMBINABLE If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing your first order and then going back to place another order. Do so as many times as you like. This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINER™ purchases Please post any technical questions to the thread so others who have similar questions can read the conversation. Place Orders Here @ www.monstaliner.com . . |
Chemical Trickster
Member # 45111
I would say yes, slightly. The surface feel of the 98 gray is very different from the 970 satin black. The 970 is kind of slippery because its has flattening agent that floats to the surface of the coating. It's a little slick feeling. The gray is glossy with a very tough surface feel.
What's the application you have in mind? |
Member # 144328
wow
Well damn i just ordered 3 or 4 more to add to the 2 i have but i have alot to do now with my sons truck project and ill do my new tons with it too.ill put in an order this weekend cant pass this up awsome stuff! Thanks Eric
Trevor Last edited by Tazer15; 11-26-2010 at 07:37 PM. |
#8 (permalink) | |
Chemical Trickster
Member # 45111
Nice to see you over here. How is that project of yours going? Let me know if you need any help. Regards MagnetMan |
Chemical Trickster
Member # 45111
CHASSIS SAVER Impact Testing
I just remembered this video. Have no idea who this guy is but he seems happy with the product. This really is the ultimate test for Chassis Saver.
YouTube - CHASSIS SAVER TEST |
Member # 144328
projects
Both are going ok its getting cold im running out of time. ill try and get some pics of installed saver on here tonight.this is nasty stuff guys better take advantage of this deal 2 for 1 cant beat that!Eric is top notch we met on another forum i made some installation mistakes and he took care of me anyway FREE of charge on another product he sells.
Chemical Trickster
Member # 45111
Good until Midnight Tonight
............................................... ![]() 2 for 1 CHASSIS SAVER™ Sale 3 Days Only - Friday 11/26 thru Sunday 11/28 Available Only Online - Not Available in Stores For anyone not familiar with this product, CHASSIS SAVER™ is a direct replacement for POR-15 at up to 45% lower cost. We have been manufacturing CHASSIS SAVER™ for almost 20 years and it has been proven under the harshest conditions. In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance facilities use CHASSIS SAVER™ for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance. Starting Friday 11/26/10 at 12:01 AM thru Sunday 11/28/10 at Midnight all CHASSIS SAVER™ Quarts and Gallons will be sold 2 for 1 Buy 1 Quart CHASSIS SAVER™ Get 1 Quart FREE - Coupon Code: CSQT-B1G1F (1 Quart price $34.75) Choose 2 of same color or 2 different colors Buy 1 Gallon CHASSIS SAVER™ Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F (1 Gallon price $97.50) Choose 2 of same color or 2 different colors ************************************************** ************************************** To get the free item, YOU MUST PUT 2 ITEMS IN YOUR SHOPPING CART BEFORE APPLYING THE COUPON CODES ************************************************** ************************************** Standard UPS shipping rates apply - $9.00 for 2 Quarts, $15.00 for 2 Gallons Place Orders Here @ www.monstaliner.com Colors/Finishes available are as follows: UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade synthetic, acrylic or urethane enamel. UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoating is not needed unless change of color is desired. UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors. UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control. Note: Use of gloss black is recommended over Satin Black if you know ahead of time you are going to topcoat. ![]() Note: Chassis Saver™ can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep. After 24 hours scuff sanding is required. Please see Technical Data Bulletin link below for complete directions on surface preparation and application. CHASSIS SAVER™ Tech Bulletin CHASSIS SAVER™ Material Safety Data Sheet ------------------------------------------------------------------ Further Details: The Coupon Codes above ARE NOT COMBINABLE If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing your first order and then going back to place another order. Do so as many times as you like. This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINER™ purchases Please post any technical questions to the thread so others who have similar questions can read the conversation. Place Orders Here @ www.monstaliner.com . . |
#12 (permalink) |
Member # 43067
awesome
Is this deal still on? I want to get a gallon to do the inside of my XJ. i gutted it and wire brushed the entire thing.
What color do u reccommend. i threw out the carpet.
* HOWEVER, if the ponies are not there in the first place, then you'll never have it when you need it. I'd prefer to have it and make an odd mistake here and there, than to not have it and really need it.-Dustin Webster Can anybody really beat Shannon Campbell if his car holds together?-771indy |
#14 (permalink) |
Member # 43067
pm me
Bedliner please. pm me so i can purchase this from u guys. Thanks
#16 (permalink) |
Chemical Trickster
Member # 45111
For any last minute holdouts
The promo below has been extended thru Midnight tonight.
2 for 1 Chassis Saver Sale! Read below in the thread for Coupon Codes and how to order. Just for everyone's info: With this promo, 2 Gallons of Chassis Saver costs you just $112.50 delivered. Compare this to POR-15 currently selling at the offensive price of (going to check online now).... 1 Gallon = $143.00 + shipping (1 Gallon!!!) So that would be $286 + shipping for 2 gallons of POR-15 ![]() 2 Quarts of Chassis Saver is $43.75 delivered 1 quart of POR-15 = $44.95 + shipping, 2 quarts $89.90 + ship Last chance saloon closes at midnight tonight. |
