CNC Plasma, Router, Torch Tables... Pirate discount! - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 03-23-2012, 08:24 AM   #126 (permalink)
Member # 196207
http://www.facebook.com/pages/The-Ru...3877363?ref=ts
[COLOR="Lime"][SIZE="4"]CNC Plasma, Router, Torch Tables[/SIZE][/COLOR] :D
[SIZE="6"][URL="http://burntables.com"][COLOR="Yellow"]BurnTables.com[/color][/URL]
[/size]
(512) 843-2621
[url]http://www.facebook.com/BurnTables[/url]
Forum: [url]http://www.texas4x4.org/burntables-134/[/url]
Riggen Industries is offline   Reply With Quote
Old 04-03-2012, 06:51 AM   #127 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 04-03-2012, 01:38 PM   #128 (permalink)
Member # 196207
Make your own Tombstone with concrete engraving from BurnTables.... Yes!!
[/size]
(512) 843-2621
Old 04-03-2012, 08:42 PM   #129 (permalink)
Member # 84719
What software do you recommend for 3d routing?
nigels_world is offline   Reply With Quote
Old 04-04-2012, 05:45 AM   #130 (permalink)
Member # 196207
The software we provide is able to do 2.5d routing, where you take 2d drawings, and by adding depth and different type of routing tools, you obtain a 3d shape or sign.
Or are you taking actual 3d models and wanting to rout them out of material?
[/size]
(512) 843-2621
Old 04-04-2012, 09:10 AM   #131 (permalink)
Member # 196207
The THC system that is on our tables was completely developed by us here at BurnTables, it is by far the easiest THC system to use, but has all the features that a $5,000 system would and more!
-Adjustable torch height control, pierce height control, pierce delay, anti dive speed, and torch adjustment speed, all adjustable on the fly while cutting!
-All settings are saved, even in the event of power loss!
-Do you only want the system to reference the pierce height, but not use the thc for that occasional odd cut part, yes it can!
-Consumable wearing out but still cutting, but the height has changed because of the wear on the consumable? Don't change it out, get more life out of your consumables, adjust the torch height by the turn of the knob, on the fly while your cutting!
-Are you getting slag build up on the nozzle? Don't stop cutting, raise your pierce height with the turn of the knob, save time make money!
-Cutting the holes in you part at a slower speed but don't want the THC to fight you and drive the torch into the material, With BurnTables antidive features, complete adjustability, and you guessed it.... on the fly! Keeps the torch from diving down in corners also, no matter how slow you go!
-Need cut a part out of a already bent part, with the BurnTables z axis ability to travel 6" and the Automatic Torch Height control, you can cut up to 45 degree bent parts.
-Have a situation that you need to completely turn off the THC, but yet need the functionality of the z axis to raise and lower between cuts, yep got it covered.
Did we mention that this all Standard on ALL of our CNC Tables!
[/size]
(512) 843-2621
Old 04-05-2012, 05:45 PM   #132 (permalink)
Member # 196207
Oxygen acetylene Cnc cutting - YouTube
[/size]
(512) 843-2621
Old 04-09-2012, 05:41 AM   #133 (permalink)
Member # 196207
Name:  burns design center.jpg
[/size]
(512) 843-2621
Old 04-11-2012, 10:22 AM   #134 (permalink)
Member # 196207
1" plate cut by a customers BurnTables CNC Oxy/Acc table, used to mount the tooth on the side of the bucket.
[/size]
(512) 843-2621
Old 04-14-2012, 08:38 PM   #135 (permalink)
Member # 196207
Had a great time this weekend showing our tables to some great people, and dodging some tornados.
[/size]
(512) 843-2621
Old 04-17-2012, 06:23 AM   #136 (permalink)
Member # 196207
Baileigh
[/size]
(512) 843-2621
Old 04-19-2012, 08:24 AM   #137 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 04-19-2012, 11:57 AM   #138 (permalink)
ssyork's Avatar
Member # 85758
That's the biggest jalapeno smoking rack I've ever seen
96 s10 blazer build
http://www.pirate4x4.com/forum/chevy...ng-bluggy.html
ssyork is offline   Reply With Quote
Old 04-25-2012, 06:25 AM   #139 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 04-30-2012, 06:25 AM   #140 (permalink)
Member # 196207
Name:  foot pedel.jpg
[/size]
(512) 843-2621
Old 05-01-2012, 09:01 AM   #141 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 05-01-2012, 02:37 PM   #142 (permalink)
Member # 196207
4x4 CNC Plasma by BurnTables with downdraft.
[/size]
(512) 843-2621
Old 05-07-2012, 06:27 AM   #143 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 05-08-2012, 06:17 AM   #144 (permalink)
Member # 196207
BurnTables CNC Tubing Cutter - YouTube
[/size]
(512) 843-2621
Old 05-09-2012, 08:04 AM   #145 (permalink)
Member # 196207
Name:  tube notcher.jpg
[/size]
(512) 843-2621
Old 05-10-2012, 05:45 AM   #146 (permalink)
Member # 196207
2 1/4" knock wrench cut out of 1'' plate
[/size]
(512) 843-2621
Old 05-14-2012, 06:53 AM   #147 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 05-14-2012, 07:29 PM   #148 (permalink)
Member # 196207
[/size]
(512) 843-2621
Old 05-14-2012, 09:30 PM   #149 (permalink)
Member # 184847
more info/ pics of the tube cutter your web site doesn't not offer up anything
North Shore Fab is offline   Reply With Quote
Old 05-15-2012, 06:19 AM   #150 (permalink)
Member # 196207
This picture shows the tube cutter attached to a 4x4 table before the factory supplied grate is installed on a customers table.
The Tube Notcher Attaches to any BurnTable CNC Plasma Table. Allows the use of table with out interfering with flat plate cutting. It is installed in a way that it allows the use of the length of the table. (On a 5x10 table, you can chuck up a 10' long piece of tube and cut the notch the end!)
3 jaw Self-Centering Chucks; Maximum Diameter Tube: 6 " diameter; Jaw Type: Two Piece Hardened Reversible Jaws; Thru Hole Size: 1.570.
$2,500.00
Upgrade to a 1.75" through hole chuck for $750 more.
[/size]
(512) 843-2621
