Why do vacume pumps cost so much? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2012, 02:13 PM   #1 (permalink)
pyrogeek's Avatar
Member # 173323
I was looking on the internet and I've found alot of them, anywhere from $10.00 on sale at Harbour Frieght to $15,000.00. Does anyone know why they can get so exspensive? I was looking at one, that i think would work for a 4'x4' table, and the specs said 56 CFM at 45 inches of water $800.00. 56 CFM isn't that much and 45 inches of water is less than 2 psi, I have found shop vacs with higher ratings than that. Shop vacs don't cost $800.00 dollars, so what am i missing? Any 2 cents will help, and thanks in advance.
pyrogeek is offline   Reply With Quote
Old 01-16-2012, 03:12 PM   #2 (permalink)
Member # 84593
Are you talking about vacuum pumps for a material hold down table for a router?
HardcorewannabeXJ is offline   Reply With Quote
Old 01-16-2012, 03:20 PM   #3 (permalink)
pyrogeek's Avatar
Member # 173323
yes sorrry, i can't spell.
Old 01-16-2012, 04:04 PM   #4 (permalink)
Member # 83940
I have a couple that were used for fiberglass/ composite layups if your interested. Price difference is how long they are made to be on. Say you are trying to hold vacuum for 24 hrs, that harbor freight is going to burn up. Even ones at 5000 dollars burn up. There are also oil and oil less ones. Some need oil changed after one long cure time. These things get hot. Also, I have seen some that have there own cooling system, radiator and fan. I dont know how long it take to router something out, but look into the time span that these are made to run. Also the amount of vacuum they can pull, 30lbs is alot and even max for most pumps. That is all I really know.
S1036s is offline   Reply With Quote
Old 01-16-2012, 09:47 PM   #5 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
not sure about the OP but i know when i router for me my max time is usually 20 min. usually around 6 mins on my machine
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 01-16-2012, 10:11 PM   #6 (permalink)
Member # 116416
30psi of vacuum isn't possible on Earth.
How much does a router push? The bigger the piece being worked on, the lower the vacuum requirements. Figuring out how much force you need would likely be a good start, this certainly isn't my forte.
lumberjack1986 is offline   Reply With Quote
Old 01-17-2012, 07:45 AM   #7 (permalink)
Member # 83940
I could of sworn I have seen 30psi, but that would be in gauge calibrations as well. I know that 28 is pretty good for bonding composites. These would be more then enough to hold the sheet.
Old 01-17-2012, 07:59 AM   #8 (permalink)
Member # 116416
Vacuum pressure cannot exceed atmospheric pursue. Perhaps you're thinking inches of mercury as atmospheric pressure is 14psi, give or take.
Old 01-17-2012, 08:27 AM   #9 (permalink)
Member # 89324
Unless it's a black hole generator, that's why they're so expensive!
Conrad_Turbo is offline   Reply With Quote
Old 01-17-2012, 09:54 AM   #10 (permalink)
Member # 83940
Yes, sorry for the confusion
Old 01-17-2012, 10:03 AM   #11 (permalink)
Member # 151733
If you want an amazing vacuum pump get a "Nash" pump. It's insane the vacuum they will pull. We have them at work anywhere from 1hp to 500hp. They are designed to run at full vacuum 24/7 they use water as a seal.
http://shop.mobileweb.ebay.com/searc...h+pump&x=0&y=0
stealthshooter is offline   Reply With Quote
Old 01-17-2012, 06:47 PM   #12 (permalink)
Member # 198946
There are the plastics thermoforming how to sites that detail using a shop vacuum for vacuum forming. Ill bet it would work as well as a vacuum table.
Course it will be really noisy.
metzindustries is offline   Reply With Quote
