Need Help Fast - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2012, 04:08 PM   #1 (permalink)
Member # 128314
Need Help Fast
Need to cut some pieces out tonight only to come home and find that the plasma won't come on.
What I have:
TM 2x4
Lincoln Pro-Cut 80
Machine Torch
Hand Torch
What the problem is:
Signal Generator tells the torch to fire, air comes on, no fire. Saftey light flashes once, but doesn't stay on.
Press air purge and safety light comes on solid and stays on until reset is pushed.
What I've Checked:
Tried changing consumables several times.
Turned on and off everything several times.
Checked cable end into machine.
Verified no water moisture in lines. (three water traps)
Hooked up hand torch and it works properly (to verify machine function)
Any Ideas? Really need to get this stuff cut tonight, but I'm at a loss
Major Metal Fabrication & Supply
Torchmate 2x4 - Lincoln Pro-Cut 80
diabloed is offline   Reply With Quote
Old 02-23-2012, 07:45 PM   #2 (permalink)
Member # 128314
Came out 2hrs later and tried again...
It fired up and cut through about half the program and then stopped firing and is back to the way it was earlier
Old 02-23-2012, 07:57 PM   #3 (permalink)
Newbie
Member # 183543
Have you checked your ground clamp to make sure you have a good clean connection?
TJ98 is offline   Reply With Quote
Old 02-23-2012, 08:30 PM   #4 (permalink)
Member # 128314
It's hooked to the end of the sheet of aluminum. Everything looks fine. I even clamped to a piece 1/4 and tried to pierce that. Nothing.
Old 02-23-2012, 11:25 PM   #5 (permalink)
Member # 163388
you aren't running out of air pressure are you?
SomeGuyFromOlympia is offline   Reply With Quote
Old 02-24-2012, 04:12 AM   #6 (permalink)
Member # 128314
No. I tried holding the purge down for a while trying to clear the lines or something and made sure to watch and it stays steady and constant wherever it's set.
Old 02-24-2012, 09:24 PM   #7 (permalink)
Member # 128314
Well no luck. Replaced all the water filters and couldn't get anything to work on a consistent basis.
Called TM. Didn't want to help because they don't recommend the Pro-Cut 80 to be used with the table. Something about by-passing the safety, but this machine doesn't have the safety stuff like the new ones do. It has a machine torch and is made to work with it. No problems, can't be mad it's not their machine.
Called Lincoln. Explained the whole thing to a tech. I could almost hear him shaking his head uh huh, uh huh followed by...sounds like the torch head is just wore out time for a new one. $900 for a new assembly or $300 for a new head plus local labor...um no!
Called local electrical place (Lincoln certified service center) Told him the situation and what Lincoln had to say (I think he actually chuckled a little) Said to bring it in Monday and they'll diagnose the problem and fix what needs to be fixed easy peasy.
Old 02-25-2012, 04:08 AM   #8 (permalink)
Member # 198413
Does your torch have a micro switch in it to tell the machine that the consumables are properly secured ? this has happened to me more than once. if so you may have to clean the switch and tighten the tip a little more.
Chief96 is offline   Reply With Quote
Old 02-25-2012, 07:10 AM   #9 (permalink)
Member # 128314
Yes it does have something inside the head that trips the safety when the tip is loose, but it seems to be working properly.
Old 02-25-2012, 08:00 AM   #10 (permalink)
Member # 186089
Send a message via AIM to Redline1122 Send a message via Yahoo to Redline1122
On our hypertherm had a similar problem. What it turned out to be was the consumables were to tight. set the clamp so that it when everything was just barely snugged and problem was fixed. hopefully that helps.
Redline1122 is offline   Reply With Quote
Old 02-25-2012, 10:02 AM   #11 (permalink)
Member # 128314
On this one on the cap screws on and seals against an o-ring, says tighten firmly right on it. If I loosen it a little the safety light comes on and can't be reset until tightened.
Old 03-09-2012, 10:34 AM   #12 (permalink)
Member # 128314
Finally got it back from the local electrical repair place...said the head had some moisture build-up in it and replaced a couple o-rings. Guess I replaced the three in-line air filters after the damage was already done. Hopefully the new ones will do there job and prevent this from happening over and over.
Old 03-09-2012, 02:23 PM   #13 (permalink)
Torchmate's Avatar
Member # 98865
The Procut uses a high frequency start which is most likely why it is working periodically. Is the table itself grounded?
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
