AVHC Lifter Mount Bracket on 2x2 2x4 4x4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-24-2012, 10:06 AM   #1 (permalink)
Member # 3310
Guys with the growth series, how is your AVHC Lifter Station mounted? This is the only way mine fits with the brackets supplied. The problem is that now I only have 22.4" of travel. I think I need to trash the TM mounts and build my own to turn the lift station 90 degrees and mount the back of it directly to the gantry.
JohnC is offline   Reply With Quote
Old 02-24-2012, 10:13 AM   #2 (permalink)
Member # 166674
Im on my phone but that looks like how mine is mounted and i get the full 24x24
Sent from my SCH-I510 using Tapatalk
Speed_Freak_039A is offline   Reply With Quote
Old 02-24-2012, 10:46 AM   #3 (permalink)
Member # 3310
The way mine is mounted, I can only get 22.4 of travel across the gantry before the torch hits on the left, or the back of the lifter station hits on the right.
Old 02-24-2012, 12:03 PM   #4 (permalink)
Member # 47407
You can raise the AVHC on the mounting bracket, it's slotted. It will get you real close to 24". However, when running the machine at higher speed doing anything with a lot of direction change, you will get some "flex" in the torch. Which leads to "saw tooth" edges on your cuts. At least for me it did.
ZJunderconst is offline   Reply With Quote
Old 02-24-2012, 12:25 PM   #5 (permalink)
Who took my cake?
mechanicalmongoose20's Avatar
Member # 120626
Find Jim Colts thread where he made his own mount, but from the pretty side. And there was another thread not long ago where they made a bracket to lower the mount to cut down on deflection, (this one have the lifter station 90 to how you have it mounted.)
Good luck.
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
mechanicalmongoose20 is offline   Reply With Quote
Old 02-24-2012, 12:50 PM   #6 (permalink)
Member # 170537
I have a 4x4 mine mounts right on the gantry why dont you ditch that 90degree bracket and.mount.it right on the gantry
glosasso is offline   Reply With Quote
Old 02-24-2012, 01:31 PM   #7 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
I drilled new holes in the bracket (mounted in the same direction as yours) and after making my tweaks I can cut 24x48 with plasma. z-axis is another story.
jdh239 is offline   Reply With Quote
Old 02-24-2012, 01:42 PM   #8 (permalink)
Member # 3310
I agree with all the comments about redoing the bracketry. I'm going to fab my own mounts this weekend. Just disappointed that it doesn't work "out of the box".
Old 02-24-2012, 01:42 PM   #9 (permalink)
Member # 205911
Looks like your using your manual torch bracket when you should mount the AVHC direct.
TM 4x4 with a HT PM45.....Be One With It..
invader28 is offline   Reply With Quote
Old 02-24-2012, 01:49 PM   #10 (permalink)
Member # 115338
The large back plate uses 4 allen head screws to attach it, you can disguard the 90 deg bracket and mount the lifter station to the backing plate, pull two of the existing screws out of the large backing plate and use the bolt holes, you will need to provide slightly longer allen head screws to mount it.
Dnmeistr is offline   Reply With Quote
Old 02-24-2012, 01:53 PM   #11 (permalink)
Member # 3310
I just slid the lifter station all the way up in the slots. Still collides when jogged all the way to the right.
And what was .050" of slop is now closer to .100" due to the torch being slid further down in the lift station clamps.
Looks like it, but this is the bracket they supplied with the AVHC. I called tech support, and they confirmed this is the "right" bracket.
Old 02-24-2012, 01:54 PM   #12 (permalink)
Member # 3310
Cool, I will try this! Thanks!
Old 02-24-2012, 02:09 PM   #13 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
Mine would collide too. Drilled holes higher up on the bracket and it works.
I too was disappointed that it didn't work out of the box as it should have.
Old 02-24-2012, 03:13 PM   #14 (permalink)
Member # 194708
Looks like yours is on the opposite side of the braket then mine. Will check when I get home but I get the full 24"x48" out of the box.
Torchmate 2x4 - Hypertherm Powermax 85
Zydenet is offline   Reply With Quote
Old 02-24-2012, 04:06 PM   #15 (permalink)
Member # 3310
Big thanks to Jake in Torchmate Tech Support! He just called and addressed each problem I'm having. He's sending me out replacement parts and assured me that we'd get this taken care of!
Old 02-25-2012, 11:06 AM   #16 (permalink)
Member # 184847
soooo they send the wrong part or operator error??
North Shore Fab is online now   Reply With Quote
Old 02-25-2012, 11:32 AM   #17 (permalink)
Member # 83940
sending him a whole new unit... time will tell
S1036s is offline   Reply With Quote
Old 02-25-2012, 01:10 PM   #18 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
They sent me a replacement part too, but it didn't work. They assembled my avhc backwards (like yours). It can be switched around, but I didn't bother (the back plate is what has been flipped 180 degrees). I just chucked the replacement bracket as it didn't work anyway. Modified the current one to fit my needs.
Old 02-25-2012, 07:17 PM   #19 (permalink)
Member # 3310
The lift station I originally received is bad. They're replacing it. The bracket they insist is correct, but it's a crappy design. I'll be redoing it myself.
Nice. I hope the replacement they're sending me does the trick.
