Member # 185144
Parts welding themselves to the skeleton when cut complete
So I have been cutting some 3/8" steel lately. When I'm done with the cut, I find a lot of the parts are welding themselves to the skeleton instead of a complete separation. What gives? It does this on about half the parts.
TM2 4x8 w/Integrated H20 table, AVTHC, Hypertherm Powermax 65 Semper Fi! 1999-2004 |
plasma dust huffer
what are you settings?
cut speed cut height pierce delay amps nozzle size shielded or not? THC? ill have to check my settings but when i do cut 3/8 they come out clean and 90% ready to use. i could get them closer to being totally ready to use with a bit more fine tuning, i just don't do much 3/8 thick parts.
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
#3 (permalink) | |
Member # 185144
Poerce delay :.7 65a tip shielded 65a cut 45 ipm Pierce:.15 Cut: .06 Using avhc All book specs
TM2 4x8 w/Integrated H20 table, AVTHC, Hypertherm Powermax 65 Semper Fi! 1999-2004 Last edited by jatepper; 03-02-2012 at 09:31 PM. |
plasma dust huffer
do you have a photo?
Member # 188229
I assume you are talking about portions in the middle of a cut.
A picture would be nice, but the only times this happens to me is when the electrode or nozzle is spent. At that point, it doesn't even cut all the way through in some parts. I can spot when it gets to that point by all the sparks being thrown out above the plate. We have a very large industrial air compressor, but if yours is marginal, I'd be looking into that. I suppose slowing the feed rate down could help to compensate. |
#7 (permalink) | |
Member # 185144
Member # 188229
I was having that issue too.
I have now started to cut my parts with 0.1" over cut.(I can't remember the real term, but it's on the screen with the lead in settings) Jim Colt posted something on this recently and he suggests using a lead out and also mentions about the "plasma off delay" http://www.pirate4x4.com/forum/showt...217&highlight= |
Member # 185144
OK......got my pictures finally. As you can see, I have a pretty nice lead in. The part welds itself at the end of the cut only. I have partially lifted this piece up and you can see it is stuck to the skeleton. I do not have a lead out and IIRC, the overburn was about .10.
There is a little nub where the piece did not completely sever where I had to rip it from the skeleton. This is AR500 steel...I do not have this issue with mild steel. What do you all suggest? ![]()
Member # 211136
I think your too fast on the speed.I cut 3/8 at 25 to 30 ipm with 60 amp tip and a TD cutmaster 151.
Opp's.[edit]..I just read it's ar500...but i still think it's too fast Last edited by Kmanator; 03-08-2012 at 05:10 PM. |
#11 (permalink) | |
Member # 185144
Hmmmm, I don't think so, but I'm not certain. I have a ton of low-speed dross (knocks off real easily). Maybe so, but I don't think that is the problem. Jim Colt told me that basically the cut specs for the AR500 should be the same as mild steel. Any other thoughts??
#12 (permalink) |
Member # 188229
What you are describing happens to me often.
Since I started doing the over cut or whatever its called, I don't have that problem very often. I normally use .1" of extra cut. I don't use a lead out. |
#13 (permalink) |
Member # 26393
Have you tried a straight "lead-in"? I find the straight lead-ins give me the smallest divot and best "complete cuts". Ramping in with a "curved lead-in" would sometimes leave a little uncut area at the end of the cut. If you try to do too much overburn, you can find yourself with the torch diving in the "already cut" cut path. You could also do a "lead-out" to ensure a complete cut.. but I've never bothered.
On my 1250, there is very little degradation in cut quality from start to "shnozzle" of the nozzle. However, when my consumables have a bunch of pierces on them, they do "splash back" more than a fresh set. I cut 3/8" at 41ipm with 60amps on my 1250 so I would imagine 45ipm would be pretty good at 65amps. I'd try a straight lead-in on one and see what happens..
Little CJ5 on 35s. |
#15 (permalink) |
Member # 205869
For a small fee ill gladly send you some Gcode that will fix that
ill even nest a full sheet for ya
[URL="https://www.targetsfromus.com"]Very affordable shooting target stands & AR500 targets [ www.targetsfromus.com ][/URL] |
#16 (permalink) | |
Member # 185144
Yeah, time to do some line speed tests I guess.
#17 (permalink) | |
Member # 205869
its a little more complex than just line speeds...you need to find a way to slow down the holes
#18 (permalink) |
I would first check your tip to work distance while it's operating, with a shade 6 goggle watch the arc and make sure it's running between 1/16" and 1/8". If you are having problems with severing the cut completely, going slower is generally going to allow the part to sever better due to the more time the plasma has to consume the material beneath it. Once you are getting completely severed parts, you can start bumping your speed to improve production and adjust the cut quality.
