Member # 202275
Water Table flats recommendations
Hi Group,
Hopefully this question has not been abused here, but I just got my 2x2 water table and will be ordering some flat steel today to finish it. At the moment I am looking at 11 pieces of 30.5" long 0.118" (3/16") thickness 4" wide flat stock steel of A36 hot rolled material. At the moment I am looking at about $110.53 plus tax. Is this reasonable? Should I be looking at any other steel grade? This was the cheapest I could find and I imagine cheapest is what I should be wanting, right? Or will I regret saving about $100 for going with hot rolled instead of cold rolled? Thanks for your input! |
Who took my cake?
Member # 120626
.118" is not 3/16". .118" is 11ga. 3/16" is .1875". So first figure out which one you are getting. Secondly, I use 11ga on my slats for my 2x4, seems to work out well.
"Opportunity is missed by most people because it is dressed in overalls and looks like work." |
Member # 81341
Not sure how the slat supports are made for the TorchMate water table but on my home build 2x4 water I use 11g 2" flat stock spaced every 2" and it works fine. You will never get that much weigh on a 2x2 table and 2" should be more that enough. 4" slats for a 2x2 seems like overkill to me.
Phantom CNC programmer! |
Member # 214437
The slats are fit in there on an arch so you can get away with. 125 thick steel, they won't move. I just used some old rusty .125/6" wide flat stock a friend of mine had at his fab shop. He sheared it up for me to the sizes I needed. Works fine! I also only used 10 slats because the torch can't make it all the way to one end so I didn't see the need to put a slat there.
Member # 202275
Thanks to all for the discussion!
What I would like to know is what you think is the cheapest solution that I can purchase locally? For example, if I go to metal super markets here in Dallas Texas, they have a gazillion grades and steel styles. Stell alloy, hot rolled or cold rolled? A36, 1045, 4140, AR400, and many more. I could just spend a few hours sorting it all up, but thought of asking in case this is a simple question. Maybe it is not as simple as I initially thought, considering it almost takes a metallurgy major to sort throught it all! I will try calling them. Maybe they can tell me which is the cheapest way to go. I'll share the results afterwards. |
Who took my cake?
Member # 120626
Think of slats as consumables. They will periodically need to be replaced. So get the cheapest you can find. All its doing is holding the material up. When they get cut up, beat up and jagged, lower the water level and hit the tops with a 4 1/2" grinder and call it a day.
#12 (permalink) |
Member # 26393
Go with hot rolled flat bar.. cheap and the mill scale will resist corrosion better than cold rolled..
I've had the same 3/16"x3" slats in my 4x8 table for about a year or so.. and still haven't turned all of them over to the other side yet..
Little CJ5 on 35s. Last edited by BESRK; 03-19-2012 at 01:39 PM. |
#13 (permalink) |
Member # 61598
I just built a table for my 2x2 with 3/16x 3" the steel yard didn't have the 1/8" that I originally wanted ...which I upgraded from 1/8"x1 1/2" (which I had on the table sans water for over a year with no problems) The slats are heavier than most sheets I'll ever have on the table, though it does feel sturdier when i load them on
#14 (permalink) |
Member # 212704
I know having them cut the slats here in Ohio was twice as much as ordering 2- 20 footers and using the hand bandsaw and cutting them myself. Was still 100 bucks but I had a 12good piece left over. I got mine the Fastenal but I'm a maintenance supervisor and get a discount and even better when its for me! !!
#16 (permalink) |
plasma dust huffer
i use 2"x1/8" for the slats in my water table, still are working great a few years after installing them. they are cheap and easy to replace if i ever wear them out enough to need them replaced.
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
