Powermax 45 issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2012, 07:22 AM   #1 (permalink)
Member # 61598
Powermax 45 issue
Last night after getting my platemarker working and running a test, the program stalled so the torch was firing in the same spot for a few seconds and stopped. When I went to continue the machine moved but the torch didn't fire!
only the power light was on, no air pressure lights, no fault lights. I turned everything off waited a few moment and back on and still only the power (A/C) light was on.
I am hoping that it will magically fix itself by the time I get home. But in case there is something I can do or if anyone else has had a similar issue please let me know. I'll also try the tech support when I get home.
cccbroncos is offline   Quick reply to this message
Old 03-31-2012, 11:06 AM   #2 (permalink)
Member # 61598
I thought a got this fixed...the original problem being a breaker when takeing aout one 115 leg of my 230v feed.
Same shit happened again with the platemarker program where the torch got stuck firing so I shut everything down and now I have an alternating blinking fault light and temp light.
this really blows!
Old 03-31-2012, 12:10 PM   #3 (permalink)
Member # 184847
check the manual, on the new powermax series i think they have OBD, and the light codes might be in there or a quick google search.
North Shore Fab is offline   Quick reply to this message
