Member # 195214
Aluminum Tube Cutting
I have a tube cutter and I have been doing aluminum tubes. The thing is that I get a ton of aluminum splatter stuck inside the tube and its hard to clean up. Do any of you guys have any suggestions as to how to prevent or minimize this?
I have already sprayed some of that welding spray but it didn't really help. Does this also happen with steel or is it easier to clean off? |
Member # 173323
i don't have a plasma cutter but could you just have the tube down in the water? well of you have a water table. lol
sorry just read that you have a tube cutter. which means you probably can't put the tube in a water table even if you wanted to. lol. the air ideal sound pretty good. Last edited by pyrogeek; 04-03-2012 at 06:56 PM. |
Member # 184847
water table or not just take two buckets drill a hole in the side near the bottom connect them with a length of hose and fill them half way. put a pump in one and the other under the other side of the tube. it shouldnt take much water as the water that is flowing will always be directly under the plasma. only thing with this is water doesnt flow if its level and you might have to raise one side of your table ever so slightly to get it to drain.
thats my two cents, and i think its worth something, like you taking a video of cutting some tubes |
