making a router jig - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-05-2012, 05:48 AM   #1 (permalink)
Member # 184847
making a router jig
i have a 3''x12'' piece of delron 3/4'' thick, i had never routed something that thick and didnt think i couldnt do it. my router bit only has a 1/2/ of cutting surface. i need to have these things done by tomorrow. the only options i see are
have the bit ground so it can cut down that far before it gets into the taper of the shank
find a different bit our an endmill and make an adapter
make a jig that i can cut the top side with some holes in it for pins and then flip it and cut the other half. this seems the most time consuming and i know it has been done with a radiator cap at TM and i think pyrogeek did something like this.
im really not wanting to do that last option but would be the only thing i can do with what i already have. any ideas on how to make a jig for that or pictures of one.
North Shore Fab is offline   Reply With Quote
Old 04-05-2012, 07:50 AM   #2 (permalink)
Member # 181643
Your router bit flutes are smaller in diameter than the shank? For delrin I would get a bigger router bit (flutes are slightly larger in diameter than the shank), there is small cutting load if you step into the material 1/8" or so at a time and manage your spindle/travel speed ratio. Local hardware store should have a suitable router bit.
sgalway is offline   Reply With Quote
Old 04-05-2012, 09:09 AM   #3 (permalink)
Member # 151733
If your in a pinch go to your local hardware store and pick up a rotozip bit. They have a very long length of cut. You will have to slow the feed down so you don't break it. If your lucky enough to live in a town with a lowest or home depot they sell 1/4" spiral router bits that are have a really long LOC also.
stealthshooter is offline   Reply With Quote
Old 04-05-2012, 09:27 AM   #4 (permalink)
Member # 151733
Choices from Lowes and Home depot. My local hardware stores don't carry these so I have a pretty good stock of bits in case I break one.
http://www.lowes.com/pd_57163-353-85...3D1&facetInfo=
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
http://www.homedepot.com/h_d1/N-25ec...&storeId=10051
Old 04-05-2012, 07:02 PM   #5 (permalink)
Member # 184847
thanks for the tips, after posting that i went to my machinst to see what he could do. i told him to make an adapter for some endmills i found. he was going to make a split ring collar and a 1/4 to 3/16 adapter. also had him grind down the 1/8 router bit i had. going to pic up what he made and get to work ill post pics later.
i think after this im telling people no more router work till i built a separate cnc machine just for it. setting up my router setup on an 8x10 water table to route a 3''x12'' piece of delron is less then ideal
Old 04-05-2012, 07:39 PM   #6 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
all i do is plastic. get a 1/4" streight bit and go to town. i use it for 1" plastic all the time, i step down 1/8" at a time till its though.
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 04-05-2012, 09:30 PM   #7 (permalink)
Member # 184847
only reason i am using such a small bit is the size of the holes. number 10 hole. i got the parts cut the little adapter the machinst made came out pretty sweet ill have pics up later
Old 04-05-2012, 09:33 PM   #8 (permalink)
PARANOID56's Avatar
Member # 5114
you could try doing a tool change. never tried it myself as lucklly the smallest hole is 1/4" i did try some 1/8" ones but like you said you can only cut those so deep.
1998 Honda XR650L
TLCA member #12202
Old 04-06-2012, 09:40 AM   #9 (permalink)
Member # 151733
Glad it worked out for you. Here are the endmills and router bits I have managed to gather the last couple months.
Old 04-10-2012, 08:33 AM   #10 (permalink)
Member # 41243
I know youve already taken care of this but heres a tip for future projects.
Check out Onsrud for CNC router bits. I run a big CNC router for a living and have had great success with their tools, for thick delron or any other high wear plastic I would look into the 63-776 series tool, its 1/4" diameter and has a 1.25" cutter length.
http://www.carbidespecialties.com/On...l_O-Flutes.htm
2007 sierra duramax 4x4, 2003 sierra 1500 4x4, 92 yukon 4x4
Laynez71 is offline   Reply With Quote
Old 04-10-2012, 04:49 PM   #11 (permalink)
pyrogeek's Avatar
Member # 173323
X2. 9 out 10 of my bits are onsrud and they have speed and feed charts.
pyrogeek is offline   Reply With Quote
