Publish to PDF Locks Up? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-03-2012, 06:17 AM   #1 (permalink)
Member # 128314
Not sure if it's supposed to work or what I need to make it work, but everytime I try using the "Publish to PDF" CADLite locks up?
Major Metal Fabrication & Supply
Torchmate 2x4 - Lincoln Pro-Cut 80
diabloed is offline   Reply With Quote
Old 05-03-2012, 07:44 AM   #2 (permalink)
Member # 84593
You have to have the full version of Adobe Acrobat installed on the computer in order to be able to use the Publish to PDF option. If you want something for free you can find some Print to PDF programs available online that install a PDF creator into your printers, and you can just print from TM CAD into a PDF.
HardcorewannabeXJ is offline   Reply With Quote
Old 05-03-2012, 08:26 AM   #3 (permalink)
Member # 128314
didn't think about having to use the full version. Thanks for the reply!
