Is there a way to send the table home? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-11-2012, 07:40 AM   #1 (permalink)
Member # 31009
I can't quite seem to find a home button withing the torchmate software. I feel like there should be an easy way to send the table to a previously defined 0,0... I can jog it there and get it really really close if not dead on most times, but Is there a home feature that I just can't find....it's probably staring me in the face.
-Steve
toreadorxlt is offline   Reply With Quote
Old 05-11-2012, 08:03 AM   #2 (permalink)
PWS Tech's Avatar
Member # 215917
Version 4.0.47 has a Home button that brings up the Home Axis menu where you can set a X & Y zero point and use the Seek command.
PWS Tech is offline   Reply With Quote
Old 05-11-2012, 09:33 AM   #3 (permalink)
jatepper's Avatar
Member # 185144
Once you set and zero your machine coordinates, you can got to Point>Machine Zero. It will move the gantry to the defined machine zero coordinates. Or, if your "home" is your program zero, just do Point>Program Zero.
I'm running an older version of the driver program, but I would guess the newer one is pretty similar in regard to this.
TM2 4x8 w/Integrated H20 table, AVTHC, Hypertherm Powermax 65
Semper Fi! 1999-2004
jatepper is offline   Reply With Quote
Old 05-11-2012, 10:50 AM   #4 (permalink)
Member # 31009
thanks both of you... ill search for these buttons.
Old 05-11-2012, 11:21 PM   #5 (permalink)
Member # 188229
Make sure you zero the machine coordinates before jogging the torch to the program zero point. If you forget and leave them blank, the machine does not know where machine zero is.
Richie_Rich is offline   Reply With Quote
Old 05-12-2012, 09:05 AM   #6 (permalink)
Member # 184847
what kind of table is this? if its anything other then a GS have you installed hard stops?
North Shore Fab is offline   Reply With Quote
