Member # 151733
Tool length sensing?
I was wondering if any of you use the tool length sensing with your TM? If so did you buy a sensor or did you build one? I figure I could use one of the switches I used for my limits??
Member # 13696
I have a cnc mill just use a simple ground loop as the switch. Isolate a steel plate on a piece of plastic once the bit touches the plate it 'grounds' closing the circuit like a switch. Not sure what your doing but should be accurate enough for a CNC router.
SELLOUT |
