Member # 222068
Torch fire delay
Ive been doing test cuts on my 4x4, and i have problems. First, my AVHC doesnt work correctly, it will fire and then it lowers the torch down and drags it really hard on the material. Second, my first cut is fine, but after that, my torch fires late and misses about a 1/4 that should be cut
Newbie
Member # 110493
Is your AVHC control cable making contact with your torch lead? More and more issues are popping up and they're being corrected just by separating the cables by an inch or so. They suggest leaving the AVHC control cable in the carrier and running the torch lead on the outside of the cable carrier and using zip ties to secure it.
#9 (permalink) | |
Member # 145912
You need to have the OK to move function interfaced (known on the Hypertherm end as arc transfer signal)...it is pins 12 and 14 on the rear panel CPC connector...and connects to "ok to move" on the AVHC box.....then, go through the procedure to set this up in the setup files. If it is not wired and or setup...you will get the sysmptoms you suggest.
Jim Colt Hypertherm Quote:
