Member # 121033
It's gotta be possible cause solid works can be uploaded most of the time.
89 YJ but not really back halved!?!350 5.7L 4L60E D60 14B(shaved)5.13 39" BFG Baja projects atlas 4spV2 ADS coilovers and fox bumps at the corners! BOMTEC Racing 4476 jimmy's 4x4 support team ![]() Torchmate2x4 cutting your stuff for dirt cheap!PM for quotes! |
plasma dust huffer
doesn't the BT software let you save the file as a DXF?
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
Member # 159520
Yup just found how on the SM Software, but when I open the dxf in the torchmate cad software part of the part is seperated and moved to a different location from how its saved on the SM software now. Im confused...
plasma dust huffer
it kind of sucks the DXF from BT software is separate lines. not a major deal but a slith pain to have to correct.
I MAKE SHIT HAPPEN
Member # 127462
Even though it may look like a compleat part if you zoom way in in the corners you"ll see that its broken. that has to be fixed befor you export from BT or torchmate cad will skatter the piecess. Then export as DXF
CampRock Fabrication and Mechanical |
