Lets see what you've built on your Torchmate - Page 62 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2012, 02:15 PM   #1526 (permalink)
Member # 132992
Originally Posted by larrycameron View Post
Cutting some trellis bits for new brother in law for designer entrance.
http://m.youtube.com/watch?v=TrT4M8qhefc
Torchmate 2x4 Powermax 45 with 30 amp consumables
Larry
New Zealand
Use this link instead Torchmate 2 x 4 Powermax 45 with 30 amp consumables Trellis Cutting - YouTube
-- Jeffrey R Holland
Link:
I know it. I live it. I love it!
jdh239 is offline   Quick reply to this message
Old 04-21-2012, 03:07 PM   #1527 (permalink)
Member # 172707
Cheers Jd
Larry
NZ
larrycameron is offline   Quick reply to this message
Old 04-21-2012, 03:43 PM   #1528 (permalink)
jatepper's Avatar
Member # 185144
Originally Posted by 03ramit1 View Post
That's great. A smile of a child is a great thing. He is a handsom young man. I'm sure your proud.
Very nice man. I appreciate that.
Made this for my buddy's restaurant this morning...
TM2 4x8 w/Integrated H20 table, AVTHC, Hypertherm Powermax 65
Semper Fi! 1999-2004
jatepper is offline   Quick reply to this message
Old 04-26-2012, 01:49 AM   #1529 (permalink)
Member # 172707
This is the photo of my 6 pieces of trellis.
A question for you guys. I am using a Hypertherm powermax 45 with powermax 30 consumables and I cut this with a set of new electrodes and nozzles. I
I cut at 108 ipm and the run time was 9 minutes x 6 trellis. 1.6mm
If my math is correct thats over 5000 inches.
The nozzle still looks good but the electrodes has some quite a bit of wear, does anybody know how many inches you are supposed to get out of these?
I suppose I am asking if this is good bad or average amount of cutting from the consumables?
Larry
NZ
Old 04-26-2012, 07:16 AM   #1530 (permalink)
Member # 184847
did you factor in your time to travel from pierce to pierce and the length of time to sense? they way you figured that is probably not the most accurate means. i think the number of pierces is more important then cut inches. id say they are still good
North Shore Fab is offline   Quick reply to this message
Old 04-26-2012, 02:23 PM   #1531 (permalink)
Member # 172707
Hi North Shore Fab, the software only seems to countdown when its actually cutting which probably includes the .5 second sensing as well, it doesn't countdown as its traversing between cut.
Thank you for your answer kind Sir. :-)
Larry
NZ
Old 04-29-2012, 03:54 PM   #1532 (permalink)
BESRK's Avatar
Member # 26393
Cut this license plate bracket (customer supplied DXF) from 1/8" with my 1250 and "Fine Cut" consumables. I thought it turned out pretty well. The letters are about 3/4" tall... just wide enough to hide most of the pierces. The bolt hole all the way to the right is .200" diameter..
Little CJ5 on 35s.
BESRK is offline   Quick reply to this message
Old 04-29-2012, 06:41 PM   #1533 (permalink)
Member # 15076
I haven't posted anything in here for a long while.
This one I just finished up on the installation this morning. I built a riser system for the washer at my powder coater. The conveyor guys will be there in a couple weeks to raise the entire conveyor system. The frames were all welded tube with a few tabs and brackets cut on the TM. The real help of the torchmate was on the stainless panels that made up the ceiling. I shear the majority of the panels to size and then burned out all the screw holes prior to brake forming. We bent them all up and then laid them in the frame which are upside down in the first picture. The rest are the whole system in place. With the holes all pre cut and the frames upside down, I was able to predrill 90% of the holes which made the installation a little less of a pain in the ass.
MQYJ is offline   Quick reply to this message
Old 04-29-2012, 07:11 PM   #1534 (permalink)
Member # 128314
3x7x.25 Just under 8' long bumper for the Livin Loud Party Bus. Has a 40" long strip in the back and will be lit by color changing LED's
Major Metal Fabrication & Supply
TM1 5x10 - AVHC - PM85
diabloed is offline   Quick reply to this message
Old 04-29-2012, 07:32 PM   #1535 (permalink)
Member # 15076
Originally Posted by diabloed View Post
3x7x.25 Just under 8' long .......
That was indexed I take it? Very nice job either way but especially if it was indexed.
Old 04-29-2012, 07:49 PM   #1536 (permalink)
Member # 128314
Thanks! Sure was.
Centered it on the square, moved to start point, cut the "Loud K" then slid the tube up, recentered on the square and moved to new start point, then cut the "K Livin' []"
Old 04-29-2012, 10:10 PM   #1537 (permalink)
Member # 184847
matt that first pic the new shop or the inside of the powder coater?
Old 04-30-2012, 05:21 AM   #1538 (permalink)
Member # 15076
new shop/home. That picture was taken from about the halfway point looking towards the back of the building. I only technically only have 1600 ft but it's not a problem if I spill out into the main area from time to time if I need to some larger layouts like this one.
Old 04-30-2012, 08:34 AM   #1539 (permalink)
Member # 184847
holy snikeys!!!! thats fawesome. there is a shear and brake there as well? you made out like a bandit there, really looks like you need a bigger table now to help with that spill over. we are in a bidding war on some property and looks like we should come to an agreement here in the next day or so, so i have got to down size
Old 05-01-2012, 09:46 AM   #1540 (permalink)
Member # 98865
That turned out great! I think that a lot of people don't think about cutting designs straight into tubing and pipe.
Torchmate is offline   Quick reply to this message
Old 05-01-2012, 10:56 AM   #1541 (permalink)
Member # 188229
I agree. This is the reason I extended my gantry arm off the table.
I was cutting circles in the flanges of some beams to make tees that were round.
I have also used my table to strip a leg of an angle down. This was before I extended the gantry arm, so I had to pull all the slats out and shim the angle up.
Richie_Rich is offline   Quick reply to this message
Old 05-01-2012, 11:51 AM   #1542 (permalink)
Member # 37128
I'd love to see a write up on how you set up the drawing and machine to cut out that bumper. great job
jrb4x4 is offline   Quick reply to this message
Old 05-01-2012, 12:22 PM   #1543 (permalink)
Member # 128314
Thanks! I'll work on a quick write-up and post it as a new topic so we don't clutter up this page.
Old 05-01-2012, 07:34 PM   #1544 (permalink)
Member # 143447
RV Camp Sign
Here's a sign I made today for a customer, its for there rv park the sign is 4'x4' cut out of 3/16
norcalrocksolid4x4 is offline   Quick reply to this message
Old 05-02-2012, 12:19 AM   #1545 (permalink)
Member # 184847
i like the double ring in the out line. and the male female of the smaller tree. is this something he sent you a file for and you just cut it or you created this is some cad?
what did you charge for this. if you dont mind?
Old 05-02-2012, 09:25 AM   #1546 (permalink)
Newbie
Member # 8555
Here's a custom JK vent plate we did after the customer coated it. Made it out of 1/8" aluminum so it would never corrode even if the coating came off.
Torchmate 4x4 w/THC Powermax 65
Laser Cut Acrylic
jason_paul is offline   Quick reply to this message
Old 05-04-2012, 03:55 PM   #1547 (permalink)
Member # 98865
I have stayed at that RV park. It is beautiful there! Great spot. Cool sign of their logo.
Old 05-11-2012, 06:27 PM   #1548 (permalink)
Member # 151733
Partially finished bow part I'm making for a company in Florida.
stealthshooter is offline   Quick reply to this message
Old 05-12-2012, 10:17 PM   #1549 (permalink)
Member # 132992
Just some shock mount support brackets.
Link:
Old 05-15-2012, 10:48 PM   #1550 (permalink)
Member # 132992
Teacher appreciation week. Daughter asked me to make the teacher a name plate with a dragon on it.
Link:
