Cutmaster 50 High Frequency? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2010, 05:01 PM   #1 (permalink)
Member # 64746
Wondering if the Thermal Dynamics CutMaster 50 is suitable for use on the
2x2 and how you would tell if it was high Frequency? TB
dichdoc is offline   Reply With Quote
Old 02-15-2010, 08:47 AM   #2 (permalink)
Member # 84593
I don't believe the Cutmaster 50 is a high frequency start unit. You could double check with Thermal Dynamics at 800-752-7622 if you want to be sure.
If it uses the standard SL60 hand torch it should have no issues running on a 2x2.
HardcorewannabeXJ is offline   Reply With Quote
Old 08-23-2010, 11:57 AM   #3 (permalink)
Member # 64746
I'll resurect this thread. I contacted Torchmate sales looking to get in on the current pricing and was told The cutmaster 50 is a high Frequency start unit. Having to buy a plasma at this time would kill the deal for me. Is there another option??? Travis
Old 08-23-2010, 12:05 PM   #4 (permalink)
Member # 84593
A little more information on what you are trying to do with it. Hand torch or machine torch? Overall goals? I would say that you could try grounding the cover of the Plasma cutter to a dedicated good quality earth ground, and that may reduce the high frequency interference enough to run the machine. There are several more ground steps beyond that, but it could rival the cost of a new Plasma Cutter.
Old 08-23-2010, 01:33 PM   #5 (permalink)
Member # 64746
Hand torch. Not sure what you mean for overall goals??? How would you go about the grounding. Is it realisitic or will I get the 2x2 home and be completely unhappy or worse damage the table???
Old 08-23-2010, 01:55 PM   #6 (permalink)
Member # 84593
What kind of material are you looking to cut? A lot of cutting or very rarely any use?
High frequency rarely damages any of the electrical components on the machine, most likely you would just be upset that every time the Plasma fires it interrupts the communication between the PC and the Control box.
Grounding I would usually recommend driving a dedicated ground rod, and grounding at least the case of the Plasma cutter, if not the whole machine/table/electronics to it. This should help reduce the radiance of that high frequency noise.
A 35 amp contact start Plasma cutter only runs about $750 these days and will do .25 - 3/8" material.
Old 08-23-2010, 04:46 PM   #7 (permalink)
Member # 64746
I'd be cutting mostly 1/8" to 1/4" maybe some 3/8" RARELY 1/2" steel. I'd expect to use it once every two weeks.
So if it interupts everytime it fires does it stop cutting or will it eventually make contact again and take off?
I have a large copper cable layed out under my slab that the elctrical service is grounded too (difficult to pound ground rods due to rock). Could I just connect a copper ground wire (what guage??) to this ground??
I guess the question is can I go for it while the price is low NOW and "get by" with a high Frequency Plasma with the goal of upgrading in the future when money is available???
Old 08-23-2010, 07:42 PM   #8 (permalink)
Member # 145912
Could sell that high freq start unit and buy a system with blowback start.....Hypertherm or T-D. There are a ton of used Hypertherm Powermax380's and Powermax600 out on the market. Someone on this site just got a 600 for $600, a bargain.
Jim
jimcolt is offline   Reply With Quote
Old 08-23-2010, 08:05 PM   #9 (permalink)
Torchmate's Avatar
Member # 98865
That would be my vote too. Just sell the high frequency unit and get a plasma cutter that you don't have to worry about. Longevity is sending me a couple new low cost cutters to test that are not high frequency either. You have lots of options. Without a really good ground, I would not mess with a high freq unit. Just asking for trouble.
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 08-24-2010, 05:50 AM   #10 (permalink)
Member # 64746
Good advice thank you. Travis
Old 08-24-2010, 11:54 AM   #11 (permalink)
CJHeap's Avatar
Member # 30944
Send a message via AIM to CJHeap
I just picked up a TD 1250 for $1000 . Still on the original consumables, from a shop closing.
[B]Hammers Post 1461[/B]
[B]Tellico Post 160[/B]
[B][SIZE="4"][COLOR="Magenta"] Nikita Khrushchev said[/COLOR][/SIZE][/B][COLOR="DarkRed"][SIZE="4"]"We can't expect the American People to jump from Capitalism to Communism, but we can assist their elected leaders in giving them small doses of Socialism, until they awaken one day to find that they have Communism. "[/SIZE][/COLOR]
CJHeap is offline   Reply With Quote
Old 08-24-2010, 01:10 PM   #12 (permalink)
Member # 84593
Probably a Hypertherm 1250
There are a lot of good hand units out there that could probably be had for cheap. Keep an eye out. Any Hypertherm 1000, 1250, 1650, PMax 45. Or Thermal Dynamics 81, 101, 151/82, 102, 152 would work excellent on one of our machines.
Old 08-24-2010, 01:44 PM   #13 (permalink)
CJHeap's Avatar
Member # 30944
You are correct, I was trying to get a TD 52 when I ran across this beast.
Old 08-24-2010, 02:42 PM   #14 (permalink)
Member # 145912
Thats a steal for that price....new it is about $4200....and it looks new.
Jim
Old 08-24-2010, 03:03 PM   #15 (permalink)
CJHeap's Avatar
Member # 30944
Jim
Yep, it still has the extra consumables wrapped in plastic in the side and came with a new PCH/M 102 spare parts kit.
