Torchmate X 10'x20' cutting 4" plate in Bogota, Colombia - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2010, 04:37 PM   #1 (permalink)
Torchmate's Avatar
Member # 98865
Here are a few pictures I got today from our distributor Andres down in Bogota, Colombia. That is a 10'x20' Torchmate X with an oxy-fuel torch cutting 4" thick mild steel. Andres handles all of our sales, installations and support in Central America. I have no idea what they are using those pieces for, but thought you guys might get a kick out of the pic's.
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 03-03-2010, 05:57 PM   #2 (permalink)
jduck's Avatar
Member # 26935
Send a message via Yahoo to jduck
Badass!
jduck is offline   Reply With Quote
Old 03-03-2010, 05:59 PM   #3 (permalink)
Karnage
spidr's Avatar
Member # 55444
So what's the accuracy of oxy act through 4" plate?
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is online now   Reply With Quote
Old 03-03-2010, 06:30 PM   #4 (permalink)
Sroufe7's Avatar
Member # 121758
Send a message via AIM to Sroufe7
That is wicked! Never seen such a nice cut from fuel...
Sroufe7 is offline   Reply With Quote
Old 03-03-2010, 06:41 PM   #5 (permalink)
affende's Avatar
Member # 49901
Send a message via AIM to affende
we do some work with plate that thick on a cantilever OA torch ...
the accuracy is better than you would think, but worse than you would like. thats the best way i can put it.
cuts like that are 99% setup and 1% luck. i cant make a decent cut on plate like that. our torcj guy can make some damn good cuts though.
affende is offline   Reply With Quote
Old 03-03-2010, 10:28 PM   #6 (permalink)
Member # 14396
Wow, that's a chunk of steel.
Pendleton Racing and Fab.
jeeperjer is offline   Reply With Quote
Old 03-04-2010, 08:05 AM   #7 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
That's just !
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 03-04-2010, 08:25 AM   #8 (permalink)
Torchmate's Avatar
Member # 98865
Working with thick plate is extremely challenging. You are pouring so much heat into the material. We sell a lot of dual torch setups as well because when you are trying to cut a long piece, you end up having to cut both sides at the same time. Otherwise the material will walk as you free up one side then the other. We have a couple of crane manufacturers that have to cut long strips of thick plate. You have to be smarter than the plate, which ends up being pretty difficult at times. Practice, practice, practice - like anything else I guess.
I remember another customer that cut 2' (that is two foot) thick plate with an oxy-propane setup on his Torchmate machine. Just getting the machine to go slow enough for that is tough. My jaw hit the floor when I heard that one. I have a hard time grasping how you even manipulate chunks of material like that. This was back before emailing pictures was as easy as it is, so I never was actually able to see it.
WWW.TORCHMATE.COM
Torchmate CNC Forum here: http://www.pirate4x4.com/forum/forumdisplay.php?f=125
Old 03-04-2010, 06:49 PM   #9 (permalink)
Greatlakeoffroad's Avatar
Member # 32466
Send a message via Yahoo to Greatlakeoffroad
Another tip is to use nails to wedge in the cut to keep it from walking as you cut (if you only have a single headed torch) Leave the nails in the gap cut by the plasma til the plate has cooled some and then remove. You would be surprised how well this works.
http://www.greatlakeoffroad.com
Don't Forget Your Discount enter Pirate10 to get your 10% discount off
Greatlakeoffroad is offline   Reply With Quote
Old 03-04-2010, 07:23 PM   #10 (permalink)
Member # 11622
I cut lots of plate between 1" and 10" at work. I started running the water table all the way up, submerging the bottom 2" of the plate, and cutting anything between 1" and 2" completely submerged. That got rid of practically all of our plate walking.
I got some funny looks from the guys when I would throw a 2" plate up there and cover it with water..... it doesn't seem like it would work.
Kamikaze is offline   Reply With Quote
Old 03-04-2010, 08:06 PM   #11 (permalink)
Torchmate's Avatar
Member # 98865
Most people don't realize that oxy-fuel cutting is a chemical process. It makes sense that as long as enough preheat is still making its way ahead of the torch, the chemical reaction will keep going. I can see where it would help keep the rest of the plate cooler so that it won't walk. Now you have me wanting to try it in our shop. I want to try the nail thing that Greatlakeoffroad suggested too. It seems like there is an art to cutting that thick plate well.
WWW.TORCHMATE.COM
Old 03-05-2010, 04:23 AM   #12 (permalink)
Member # 11622
It took a good year or two before I got good a cutting the heavy stuff. It is more by feel than anything. If you do decide to cut with the water up, I have found that bumping up the cutting oxygen pressure bu a good 20-30 psi over the recommended keeps the slag off the bottom. The big thing with heavy plate is that slower and hotter isn't always better. Its crazy the difference .1 IPM can make on a cut, and a few psi here or there.
Old 03-05-2010, 06:09 AM   #13 (permalink)
Member # 32466
6D or 8D nails depending on the mtl being cut usually works pretty good, we keep a bag or two handy. I have also cut long (20') 3/16" AR strips (6" wide) and actually used small strips of steel and tack welded them together after the cut as we were working across a sheet of steel. It kept the sheet rigid and kept the walking to a min. down side to this is having to knock off the tabs w/ a hammer and grind the tack off smooth again. But it worked and saved the high dollar plate.
Old 03-05-2010, 07:46 AM   #14 (permalink)
Member # 57412
Send a message via AIM to Speedy2222 Send a message via MSN to Speedy2222 Send a message via Yahoo to Speedy2222
that is an awesome cut. I remember where i use to work they had a torchmate and were trying to cut 1" plate with the oxy/acet torch and they had slag dripping off of them and were very rough, i was always telling the owner he was doing it wrong but he insisted that that's how an oxy finish should be. I can now prove him wrong.
Speedy2222 is offline   Reply With Quote
Old 03-05-2010, 01:00 PM   #15 (permalink)
Member # 11622
Yep, if you know what you are doing you can get a finish like that on 10" plate. It is a delicate balance of fuel pressure, cutting pressure, and fead rate.
Old 03-06-2010, 09:39 PM   #16 (permalink)
bigtoy302's Avatar
Member # 36440
Nice. I Just got done machining a piece at work that was oxy cut from 14" a36 48" in diameter.
bigtoy302 is offline   Reply With Quote
Old 03-10-2010, 03:47 PM   #17 (permalink)
Member # 11622
I had to cut some 3.5" plate today and happened to have my camera handy. Figured I would shoot some video and snap a few pictures. You can see how much the water keeps the part from walking in the pictures. I did screw up on the hole, I thought I chipped enough of the slag out of the way from the pierce but I missed it by a hair and it stopped the cut......
YouTube - cutting 3.5" plate with water
Old 03-10-2010, 03:50 PM   #18 (permalink)
Member # 11622
A little off topic but we had a tour come through so I put together a real quick demo with our robotic welder. I wish I would have had a few hours to really show out with it but I did the best I could with the few minutes I had.
YouTube - robot welder demo
Old 03-11-2010, 03:42 PM   #19 (permalink)
Torchmate's Avatar
Member # 98865
I spent some time talking to Andres yesterday. I showed him Pirate and this thread. He said that once they originally got the machine setup, he said let's run a sample. They brought over a 4" thick slab that wieghed like 6000kg (over 13,000lbs). He said, "you want to test with that?". They said, "We have parts to cut, let's go". Talk about being put under the gun. No problems, but I know he was sweating on that first cut.
WWW.TORCHMATE.COM
