z axis? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2010, 03:08 AM   #1 (permalink)
Newbie
Schmaus's Avatar
Member # 17258
z axis?
Would it be possible to use to router z axis to plasma cut. That way you can have a pierce height and a cut height. Plus you could lift the torch for rapid movements.
Schmaus is offline   Reply With Quote
Old 03-09-2010, 07:37 AM   #2 (permalink)
Member # 145912
Depends what you have for a machine. For a full functioning torch height control for plasma....you need a method of sensing the location of the plate surface before each cut, then index to the plasma manufacturers recomended pierce height (different for each thickness and power level), then index down to the manufacturers recomended cut height while still in the pierce location, then after the machine achieves cut speed use arc voltage (actual DC voltage from the plasma system as feedback to control height while cutting. If you have software that already has height control functionality you are partway there!
Jim
jimcolt is offline   Reply With Quote
Old 03-09-2010, 08:12 AM   #3 (permalink)
Member # 84593
Schmaus, the Z axis deals with set "depths" for doing cuts. While on a perfectly flat piece of material this could be an option. The Z axis is not joggable during programs though, so wouldn't be a good option for material that will be constantly changing.
Most most material does not remain perfectly flat, thus the creating of Automatic Arc Voltage Height Controls. A Z axis would be just as bad if not worse then a manual height adjustment.
HardcorewannabeXJ is offline   Reply With Quote
Old 03-09-2010, 08:15 AM   #4 (permalink)
Torchmate's Avatar
Member # 98865
You can use it to do what you are asking. It just won't adjust during the cut, which is what most people really buy height control to do. Pierce height versus cut height is far less of a big deal relative to maintaining the cut height. You could avoid tip ups during rapid moves the way you describe. Give a call to tech support and have them walk you through it.
Bill
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 03-09-2010, 09:36 AM   #5 (permalink)
Newbie
Schmaus's Avatar
Member # 17258
I was thinking that the z axis is only alittle more than manual z axis (2x2 table) and then I could switch between torch and router. As of now I have manual z axis ordered. but thinking of changing order to router style. I won't be using a router very often maybe not at all.
Will the software update be pricey or included for those that have not received there table.
