Yukon Gear and Axle
Member # 35700
Cutmaster A120 issue
I was cutting some 1/4" plate with a 60A tip and the machine set at 60A. I keep getting an error light and the 85 psi light blinking constant and fast. Manual mentions direct short? I increased my pierce/cut height and even disabled auto AVHC, no dice. And new consumables.
One thing I noticed, is when it cuts, I see the plasma cutting, but occasionally I'll see a second or wider plasma arc. Any thoughts? I just did some 12GA floor plate with no issues. I didn't try another sheet of 12GA to see if the problem remained, or went away. My assumption is it would cut fine.
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
When cutting at 40 amps or above, if the tip comes into direct contact with the material (and therefore the ground clamp) the cutter will shut itself off to prevent damage to the consumables. This prevents the arc from going through the copper tip rather then through the hole in the tip.
12 ga material I would recommend cutting at 40 amps or below, as you don't need 60 to cut it. 30 or 40 amps would do fine, and most likely give you a cleaner cut with less material warpage. |
#3 (permalink) | |
Yukon Gear and Axle
Member # 35700
My AVHC was on and there is a gap between the material and the tip never touches, but I still get the error. Unless I'm in manual mode, then it just stops cutting, with no error, and when it finishes that 'cut', it will relight, pierce and continue - unless it errors again. With the AVHC on, it stop when it throws the error. A friend of mine suggested relocating the ground, so I'll try that next time.
Yukon Gear and Axle
Member # 35700
no other ideas? Do I possibly have a defective machine then?
Yukon Gear and Axle
Member # 35700
o ring and cartridge are new. But I can try it anyway.
Thermal Dynamics won't treat anything as a serious issue until you replace all the consumable pieces, including the start cartridge.
If cutting at anything about 40 amps constantly gives you this error, I would at least call Thermal Dynamics and run it by them. 800-752-7622 |
Member # 98865
Wayne,
Email me (bill@torchmate.com) and let me know what happens when you call TD. Also, if you have called in to our office, then let me know with whom you have been dealing so I can follow up with them. We will figure it out even if we have to swap out the unit. When you email me, let me know the name that you purchased the machine under so that I can find you in the computer system. Bill
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/ |
#9 (permalink) | ||
Yukon Gear and Axle
Member # 35700
So far I haven't called anyone - TD or Torchmate. I've been so swamped getting parts built, that I really haven't had a chance to figure out the table. If I toss a sheet up there, and it works, then great. If not, I call my laser cutter guy and place a order for the parts. Obviously I want to get away from doign that, but until then... Should be under AllJeep.com....
Yukon Gear and Axle
Member # 35700
I believe it was only a ground issue, becuase it's not doing it anymore. And the only thing I've changed, is where the ground was clamped to. Which was changed only because I was cleaning up wiring and such....
#11 (permalink) | |
Member # 160818
_________________ Blank koozies Last edited by blankkoozies; 05-21-2010 at 08:00 PM. |
