Member # 156241
This may be a stupid question.......
I know its a 2x2 but can it actually cut a 24 in square? Which would mean material larger than 2x2. Also I have noticed that some machines used slats that are cut sort of like a saw and others are just straight bars. It would seem too me that the saw shape would last longer as it would not be cut as much as the bar style. Whats your opinion? I thought it could be a good first project to cut the saw shaped slats for the my machine.
Thanks |
Member # 29097
I asked the same questions before I ordered mine. The tool path is 24.25" so it will cut slightly larger than 24". If you add a plate marker it will eat up some of the tool path, it you mount a hand held torch on your own you could eat into the tool path depending on your mount. You can cut larger than 24" by indexing the material being cut and moving the machine or the material. The support bars should be perpendicular to the majority of your cuts to make them last longer but I know I will have to replace them from time to time.
"Those who make peaceful revolution impossible will make violent revolution inevitable." SunDog Quarter Horses |
Member # 98865
We have tried the saw tooth shape. It just results in more tip-ups. This is where the part falls partially free and then partially tips up to where the torch might hit it. Just something to keep an eye on. I have seen slats with literally 1" of slag on both sides. They last a long time, even flat the way we suggest. When they get too caked with slag, pull them out and flip them over. In a perfect world, nothing falls through. Freed parts just sit flat once they have been cut. One less thing to have to worry about.
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/ |
Member # 156241
Thanks for the info. I never thought about the parts tipping into the slats, so for sure I will make them straight. That was to date the best tip I have received. If a part were to tip in and after the head hit the part would the machine stop? Or would it try and drive through it? How easy is it to damage the machine in this way?
#5 (permalink) | |
Member # 98865
Arc Voltage Torch Height Control helps with tip-up's as well because the torch raises up 3" between cuts to avoid hitting anything. Better yet is that it does it in about a half a second so it doesn't slow you down too much. So, if you have AVHC and use flat slats on 3" centers, it takes a pretty unique part to tip up more than 3" and catch the torch while it is traversing to the next cut.
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: http://www.pirate4x4.com/forum/forumdisplay.php?f=125 |
The stepper motor control system is a open loop system, where the motors can not tell the controller there is an obstruction and it can't move any further. The stepper motors will simply stop their motion and "slip" so the machine won't move any further. The potential for damage is limited due to the fact the torch head is mounted securely in the collar which is hard mounted to the gantry. The only soft parts are the torch head itself and it is well supported and protected. On a table the size of a 2x2 it is much easier to manage and control these events then a 5'x10' machine.
#7 (permalink) | |
StinkyFab Racing
Member # 4946
Dallas Ashley StinkyFab Racing (SFR) - Custom Fabrication Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more! Overall Winner, 2012 KOH EMC. Gettin it done in a stocker! Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008 |
#8 (permalink) | |
Yukon Gear and Axle
Member # 35700
But on boring parts, I do find myself wanting to do something else.
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
Member # 98865
It definitely pays to have your slats closer together to avoid large tipups. Costs a little more to put them in, but saves you from having to sit there and watch it. Our guys here will spend a little more time nesting small parts so that they have the least chance of tipping once free. That allows them to go do something else when the machine is processing a plate.
Member # 66858
More form the laser guy;
To avoid tip ups I always tab my parts in, just enough that they shake out later. They next evolution and I am guessing it is how the bigger machines work. Would be servos with collision sensing. Even steppers with linear encoders would work for this.
Member Deep Woods Extreme 4X4 Club Of Southern NH. |
