Front Mounted Plate Marker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2010, 12:58 PM   #1 (permalink)
Boyd Welding LLC
Dave Boyd's Avatar
Member # 141166
When i researched the plate marker i knew it was designed to mount next to the plasma which in turn hindered my ability to cut a full width sheet (48"). that was not acceptable and torchmate did not have a solution so i purchased it anyways with the intention to design my own front mounting system. this is what i came up with and it works great.
Bill advised me from the beginning that there may be issues with the down force of the platemarker pushing the linear slide up. i found that not to be an issue, however the weight of the plate marker and this bracket did tip the slide over (forward). You must have Cam followers on the bottom of the X-Axis rails.
Dave Boyd / CEO
www.boydwelding.com
PHONE:352-447-2405
TOLL FREE: 877-270-3576
FAX 352-447-2403
EMAIL: daveboyd@boydwelding.com
Dave Boyd is offline   Reply With Quote
Old 03-29-2010, 03:44 PM   #2 (permalink)
Torchmate's Avatar
Member # 98865
Thanks Dave! I really like this setup. Good spacesaver. I can see where using the lower bearing mounts helped stabilize the whole thing. Shows how much weight you can hang off that extruded aluminum. People don't realize how strong that stuff really is.
The credit is there when you need it. I know you refused it, but I did it anyway. I really appreciate your willingness to help out the other folks on this board. It is exactly what I hoped having a Torchmate specific section would do. Allow people to share their idea's and knowledge. Thanks again!!!
Bill
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 03-30-2010, 05:36 AM   #3 (permalink)
Member # 15076
Nice setup Dave!! I like that a lot. I have a couple sketches of an adapter plate to put the plate marker right up close aside the torch and positioning them both pretty much in line with the center line of the yaxis drive motor. I don't remember the exact dimensions but I think I had it figured out to get both torch and plate marker within an inch of either side of a 4' sheet and not lose any x axis travel.
Doing what you did, do you lose any xaxis travel?
MQYJ is offline   Reply With Quote
Old 03-30-2010, 07:33 AM   #4 (permalink)
SoundManCO's Avatar
Member # 29097
I emailed my sales rep (Andy, got to give the guy props, he has been a big help) and asked how much tool-path I would lose with the plate marker and it is more than I am willing to loose on the 2x2. After seeing this I may get the marker anyway and make a mount for the hand held torch mount in front of the plate marker.
Are there any issues with the torch being very close to the plate marker? Dross blowing back up, heat or anything that I may not be considering?
"Those who make peaceful revolution impossible will make violent revolution inevitable."
SunDog Quarter Horses
SoundManCO is offline   Reply With Quote
Old 03-30-2010, 07:53 AM   #5 (permalink)
Boyd Welding LLC
Dave Boyd's Avatar
Member # 141166
sometimes our parts are 47.875 so i had to make sure i could cut a full 48". Yes i lost over 6" of X-Axis movement, however i'm not concerned with that.
Dave Boyd / CEO
www.boydwelding.com
PHONE:352-447-2405
FAX 352-447-2403
Old 03-30-2010, 08:17 AM   #6 (permalink)
Boyd Welding LLC
Dave Boyd's Avatar
Member # 141166
The plate marker is actually farther away from the plasma as originally designed. Dross blowing back up doesnt seem to be an issue. cutting .188 aluminum or thinner doesn't produce really enough heat to hurt anything.
Dave Boyd / CEO
www.boydwelding.com
PHONE:352-447-2405
FAX 352-447-2403
Old 03-30-2010, 08:30 AM   #7 (permalink)
Member # 84593
The plate marker can remain very close to the torch without any issues.
On a 2x2 you would be loosing travel in either dimension, and since the machine is square I wouldn't see the need to develop a custom bracket to hang it off the front. With the material on top of the extrusions you would get 24" out of each tool, but not in the same "program" together.
HardcorewannabeXJ is offline   Reply With Quote
Old 03-30-2010, 08:32 AM   #8 (permalink)
Torchmate's Avatar
Member # 98865
I am with Dave. I don't think mounting the plate marker close to a plasma torch is going to hurt it. In the pic's on here from one of our big 10'x40' Torchmate X tables they have it mounted a little further away. Of course they are cutting 4" thick plate that really throws some heat. Especially when they turn that bevelling head towards the plate marker. If it will put up with this, it will handle just about any distance from a plasma cutter.
WWW.TORCHMATE.COM
Torchmate CNC Forum here: http://www.pirate4x4.com/forum/forumdisplay.php?f=125
Old 03-30-2010, 10:31 AM   #9 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Just wondering, how much toolpath are the TM guys claiming you'll lose with the normal setup? On my 4x4 I've found that if I set the machine up with the Y-zero right at the very last tooth on the gear rack I can get almost 47" of Y axis travel. The only thing that drives me nuts sometimes is if i have a part that uses both tools near the edge of a sheet, but it's just a minor annoyance.
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 03-30-2010, 10:58 AM   #10 (permalink)
SoundManCO's Avatar
Member # 29097
I think Andy told me a little over 6" of tool path would be lost. That's a quarter of the tool path on the 2x2.
Old 03-30-2010, 11:27 AM   #11 (permalink)
Member # 84593
This is the part that we are saying you lose the distance on, when you are doing both a scribe and cut in the same program. The machine travel itself is just slightly effected.
Old 03-30-2010, 12:46 PM   #12 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Ok I see what's goin on. You may wanna make sure that's clear when you describe it to people on the phone. I really only lose about 1.5" of overall travel, but yes if you have to make a very tall part that has both operations in it you are limited more than that. I've just never personally had that issue cause it's rare for me to cut anything that's both 4' tall, AND 4' long. obviously for a 2x2 your dimensions are much more limited.
Dallas Ashley
Old 03-30-2010, 02:34 PM   #13 (permalink)
Member # 143178
Send a message via Skype™ to Dan DuBose
Thats a cool set up Dave
[URL="http://www.jmrmfg.com"]JMR Manufacturing[/URL]
Dan DuBose is offline   Reply With Quote
Old 03-30-2010, 05:21 PM   #14 (permalink)
Torchmate's Avatar
Member # 98865
Crap Dan, I have been meaning to call you! Man, I would forget my head if it wasn't attached. I will try to remember tomorrow. Will you be around?
Bill
WWW.TORCHMATE.COM
Old 01-03-2011, 02:20 PM   #15 (permalink)
Boyd Welding LLC
Dave Boyd's Avatar
Member # 141166
here are the pictures again as i changed our server so the originals do not show anymore.
Dave Boyd / CEO
www.boydwelding.com
PHONE:352-447-2405
FAX 352-447-2403
Old 01-03-2011, 04:18 PM   #16 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
Thanks for reposting them Dave! I already have cam rollers on the bottom side of my tracks to I may give that setup a try!
I am normally only a danger to myself don't make me include you!!
BioHazard Buggy Build Thread
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote
Old 01-03-2011, 06:15 PM   #17 (permalink)
Newbie
MetalHeadzFab's Avatar
Member # 172100
Ordered my plate marker today!
MetalHeadzFab is offline   Reply With Quote
Old 01-04-2011, 11:10 AM   #18 (permalink)
Member # 129733
i did the same. built brackets off the torch holder
sadisticiron is offline   Reply With Quote
