Our watertable build. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-31-2010, 01:35 PM   #1 (permalink)
Member # 14396
We got our 2x2 last week and started our water table build this weekend. We should have it done soon. The basic idea is to be able to index the machine to be able to cut a 48x24" sheet. Table is made out of 3x4 tubing. we should have around 3-3.5 inches of water depth. Using 2" wide .25 inch flat bars as cross slats spaced 1.5" from each other. I have started a gallery on my website that will encompass the entire build. their are more photos in it if you are interested. Link to gallery of photos is here table build
here are a few photos
squaring up the top
burning it together
Milling out the slat spacers.
slat spacers all done, I did them in 2 sections each side so they would fit on the mill better.
The slats will rest on 1x1 square tube.
Clamping/positioning slat holders to main table
burning them on.
continued....
Pendleton Racing and Fab.
jeeperjer is offline   Reply With Quote
Old 03-31-2010, 01:42 PM   #2 (permalink)
Member # 14396
test fitting slats
close up of slat holders
Here is the torch holder I made out of aluminum on the mill. I still need to get a handle of some sort so i dont have to use a Allen key to adjust the height.
front view
this is the replaceable torch holder, it holds our miller 625 torch perfect, and can be changed later if we need to.
If you want any more details/photos ask away.
Jeromy
Old 03-31-2010, 02:04 PM   #3 (permalink)
Torchmate's Avatar
Member # 98865
Looks good! Have you had a chance to play with the machine. Just practicing moving it around. What do you think?
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 03-31-2010, 02:50 PM   #4 (permalink)
Member # 14396
We had it zipping around a bit Saturday. Pretty cool machine, we are really excited to get it cutting. Hopefully by the end of the week.
Old 04-02-2010, 04:47 PM   #5 (permalink)
Member # 63280
Send a message via MSN to brooksy1
Looking good. Thinking about getting one to Australia for my workshop
brooksy
C44F-Custom 4x4 Fabrications Australia
project - "STRETCH" LS1 FJ40 105"wb
brooksy1 is offline   Reply With Quote
Old 04-02-2010, 11:01 PM   #6 (permalink)
Member # 14396
got a bit more done tonight. got the legs built. legs are 3x2 .120 wall tube with 1.5 inch cross beams. Tomorrows plan is to burn it all onto the bottom of the top.
Here are the quickie adjustable feet i made, just a 3/4 inch bolt taped into a 3/8 plate that was welded to the bottom of each leg
view of the legs mocked up on the bottom of the table. Each side was tig welded together. next is to square up the sides to each other and the table.
close up of one of the tig beads, my buddy's, not mine, mine were not photo worthy! weld mold rod was used.
Old 04-02-2010, 11:02 PM   #7 (permalink)
Member # 14396
brooksy
thanks!
Old 04-03-2010, 04:22 AM   #8 (permalink)
Member # 66858
Why not cut the slats on the plasma table in the first place. I always programmed a couple slats into my jobs if there was a little scrap, so I always had some new ones coming off.
WRT indexing, I have ran lasers for years and even with 6'X10' tables we still needed to index ocasionally. What we did was weld drill bushings into one end of the table, and laser cut holes in the scrap area somewhere. Then you would simply slide the material down and pin to the bushings and continue to cut.
Member
Deep Woods Extreme 4X4 Club Of Southern NH.
LASER is offline   Reply With Quote
Old 04-03-2010, 10:49 PM   #9 (permalink)
Member # 14396
once we get the table up and running the slats holders would be no problem. We are pretty green so far to the cnc plasma. I figured I would do a way better job with the mill. They turned out perfect, even if it take me a bit longer, and no wasted material trying to figure out the machine.
Pretty good idea on the indexing, thanks for sharing!
Jeromy
Old 04-03-2010, 10:51 PM   #10 (permalink)
Member # 14396
The frame work for the table is all welded up.
Rats nest of straps, trying to square everything up then tack it together.
A photo of me actually doing some welding. Tigging with a miller dynasty 200 dx.
all done, next is the water pan bottom.
Old 04-04-2010, 08:43 PM   #11 (permalink)
Member # 14396
the table stands on its own! got the water pan siliconed and riveted on. letting the silicone setup overnight and will test for leaks tomorrow.
view of the table with the machine sitting on top of it.
720p video of the machine running through a dry run of the included line speed test g-code. (click on photo, hope this works)
Old 04-08-2010, 10:12 PM   #12 (permalink)
Member # 14396
Unit is finaly up and running!!!
Table all finished with unit sitting on it.
ready for action
our first ever cut! we just guessed on the settings. started at 40 ipm and 30 amps on the plasma, leftover piece of metal as a test. Cutting out a IHMSA silhouette shooting chicken. Still figuring out the computer, dimensions were all askew.
YouTube - MVI_0025.MOV
the result
We are total newbies at this and I was blown away with the fact that it actually worked. We got a huge learning curve ahead of us. I need to sit down with the manual for a bit and figure out the software.
One real weird thing was the machine cut the image out backwards, ie the chicken was facing to the right on the computer screen, but the machine cut it out facing the left. we did a line speed test after using the supplied g-code and it ran in reverse as well.
Old 04-09-2010, 05:03 AM   #13 (permalink)
Member # 156241
Great build you guys did a killer job! I cant wait to get my machine. What type, size plasma are you using? Was that 1/16 thick steel you test cut?
cnc4me is offline   Reply With Quote
Old 04-09-2010, 07:52 AM   #14 (permalink)
Member # 84593
Make sure you read the setup guide for the machine, it will have you open a particular setup file with the correct gear ratio and screw thread assignments.
HardcorewannabeXJ is offline   Reply With Quote
Old 04-09-2010, 08:03 AM   #15 (permalink)
Member # 115338
Also reverse the y axis under System, Motor Signals, and your cuts will cut in the right direction.
Dnmeistr is offline   Reply With Quote
Old 04-09-2010, 10:27 AM   #16 (permalink)
Member # 14396
18gauge, we are using the miller 625, 40 amp unit. the older model, not extreme version they have on their site now. We are miller fans here.
I did that, thanks, what i ment bt the demensions all being askew is when i imported the dxf file we created in illustrator, upon import into cad light was enormous. 10x or more oversized.
thanks.
Old 04-09-2010, 03:06 PM   #17 (permalink)
Member # 43283
Man that table looks great.
Would it be possible to get all the demension from you on that table?
Why did you riveted and siliconed the pan? Why not weld in all?
Now that you have it all up and running ,anything you would change?
Just wanted to know so when i do i know why.
Thanks
EZDUZIT
EZDUZIT is offline   Reply With Quote
Old 04-10-2010, 10:21 AM   #18 (permalink)
Member # 14396
Thanks
EZDUZIT
ill get all the demencions for you later this afternoon.
We used silicone it due to past experiences with warping. I dont think we would have had a problem with the size of the frame tubing but the silicone and rivets were fast easy and if we did ever have to replace the bottom pan it would be easy.
the first thing i would change is i rattle canned it. what a pain in the ass that was. We were going to por15 the inside but the can we had on the self was bad. I need to invest in a good spray gun setup.
also im not totally happy with the feet, but they will do their job.
Old 04-18-2010, 09:27 AM   #19 (permalink)
Member # 43283
Cool can't wait to get started on my table.
Thanks
EZDUZIT
Old 04-19-2010, 12:06 PM   #20 (permalink)
Member # 14396
here are the overall dimensions for you EZDUZIT, its 32" tall, 64" long, and 36.25" wide.
Jeromy
Old 04-19-2010, 12:43 PM   #21 (permalink)
Member # 14396
so table is in its final home now and last night we cut out our first official project on it. Its just a quick little project, some house numbers. Its pretty basic stuff, but it was a good non critical project to get started with.
this evening ill get some final photos of the table ect, but here is a video of the machine at work.
Video on my site: (click on photo)
youtube version
YouTube - 2x2 project
Old 04-20-2010, 08:26 AM   #22 (permalink)
Torchmate's Avatar
Member # 98865
It looks like you have figured it out. Do you mind if I post up your video in a few other places?
WWW.TORCHMATE.COM
Torchmate CNC Forum here: http://www.pirate4x4.com/forum/forumdisplay.php?f=125
Old 04-20-2010, 02:01 PM   #23 (permalink)
Member # 14396
no problem,
Jeromy
Old 04-20-2010, 03:53 PM   #24 (permalink)
Member # 15076
excellent video!
Man, you really have to watch the tip ups on those tables without AVHC. Seeing that video makes me sure I did the right thing by getting that as part of my system.
MQYJ is offline   Reply With Quote
Old 04-30-2010, 11:16 PM   #25 (permalink)
Member # 14396
Originally Posted by MQYJ View Post
excellent video!
yeah, AVHC would be nice! That was super thin stuff and we had the plasma cranked, i dont think it would be as bad if we turned it down.
Jeromy
