AutoCad to TMCad - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-05-2010, 01:27 PM   #1 (permalink)
Liquid Iron Ind.
Timmay's Avatar
Member # 52894
AutoCad to TMCad
I used AutoCAD 2007 to trace out a drawling i had and used the spline tool to do most of it. When I imported the DXF to TMCad and connect the path it makes it look nothing like what I drawn out. Same thing happens when i try using the ellipse tool. Any ideas?
Tim Diekmann
Liquid Iron Industries, LLC
tim@liquidironindustries.com
http://www.liquidironindustries.com/
(856)-336-2639
https://www.facebook.com/liquidironindustries
Molten Motorsports #4343 "Fred"
Timmay is offline   Reply With Quote
Old 04-05-2010, 02:23 PM   #2 (permalink)
Torchmate's Avatar
Member # 98865
I know that the Spline tool comes in funky. Grab your drawing in AutoCad and change it to a polyline before you export it. I have not dealt with it in awhile, but worst case you can email the file to tech and they can tell you what to change it to in AutoCad before you import it to Torchmate CAD.
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 04-05-2010, 02:27 PM   #3 (permalink)
Member # 151150
Same with the ellipse tool im guessing too
Kyle
K Mc is offline   Reply With Quote
Old 04-05-2010, 02:38 PM   #4 (permalink)
Member # 84593
Splined DXF's are definitely a pain, convert it once traced in Autocad to a polyarc or polyline and see if that comes in better.
HardcorewannabeXJ is offline   Reply With Quote
Old 04-05-2010, 03:49 PM   #5 (permalink)
Member # 11684
All CNC software seems to hate splines, it's not just limited to the Torchmate stuff.
As far as ellipses go, you need to change a variable in AutoCAD through the command line from 0 to 1. I need to look back through my notes to see what the variable is called. You only have to do it once (unless you re-install AutoCAD). It just changes the way in which the maths that is the guts behind the ellipse is presented.
EDIT: The variable that needs to be changed is PELLIPSE
I may have the value wrong ie: it may need to be 0, not 1. When you type PELLIPSE into the command line it will return the current value on screen anyway, so just choose the other value
wendleburger is offline   Reply With Quote
Old 04-18-2010, 06:03 PM   #6 (permalink)
JeepCrawler98's Avatar
Member # 18342
Send a message via AIM to JeepCrawler98
Did this work for you? I've had good luck running .dwgs through Corel draw, then exporting from Corel into a DXF (works perfect every time with the local steel shop that uses TorchCAD, theirs freaks out when opening AutoCAD DXFs).
98 TJ, goin crazy with the sawzall
[url=http://www.4x4tj.com]www.4x4tj.com[/url] - the Jeep
JeepCrawler98 is offline   Reply With Quote
Old 04-18-2010, 07:22 PM   #7 (permalink)
Ruiner of the Things
AlxJ64's Avatar
Member # 130031
I've been running AutoCad 2004 Student version and found that when I import into TMcad that coverting it over to Polyarcs usually makes things work. Another thing I will do is sometimes splines are not fully connected so the toolpath is not applied correctly. I will select the entire part that needs to be closed and tell the machine to connect the path and just give it like a .01 tolerance rather than allowing it to be a .0001 or whatever it is way out there. So far its worked for me on most of my drawings.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps
http://www.pirate4x4.com/forum/showt...=781656&page=3
'42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins
http://www.pirate4x4.com/forum/tow-r...airstream.html
AlxJ64 is offline   Reply With Quote
