Member # 50132
whats everyones feedrates
I have a TD cutmaster A80 , just curious as to what feedrates others are at with similar plasma cutters? Mainly smaller stuff 1/8", 3/16", 1/4" etc..... Trying to see if i'm in the ballpark? I am at 80 ipm w/ 1/8", 65 w/ 3/16" and 55 w/ 1/4". I also slow the arc rate down to 70% of those numbers.
Member # 26393
I cut with a HT1250
1/8" at about 40amps and 60-65IPM using "fine cut" consumables 3/16" at about 40amps and 45IPM using "fine cut" consumables 1/4" at about 60amps and 55IPM using 60 Shielded Nozzles 3/8" at about 65amps and 45IPM using 80amp Shielded Nozzles I usually check the first few pieces and adjust voltage (height adjustment) if I need to. I also check height periodically while cutting.
Little CJ5 on 35s. |
Member # 84965
TM3-5x10
Hypertherm 1250 AVHC - I only run in auto mode for large parts or warped sheets. -I always ground directly to my sheet, not to the slats. -My Numbers are based off of my hypertherm manual, then i've adjusted from there to what i've found works better on my table. 1/8" -finecut @ 40a -49 ipm - AVHC @ 83 volts 1/8" - finecut @ 50a - 88 ipm - AVHC @ 77 volts 3/16" -40a @ 40a - 60 ipm -AVHC @ 147 volts 1/4" -60a @ 60a - 83 ipm -AVHC @ 138 volts 1/4" - 80a @ 80a -102 ipm -AVHC @ 134 volts 5/16" -80a @ 80a - 80 ipm -AVHC @ N/A 3/8" - 80a @ 80a - 60 ipm -AVHC @ 137 1/2" - 80aa @ 80a - 37 ipm - AVHC @ 140 I'm going to try and use some of the lower amperage and slower speeds you guys are talking about and see how they work too. Right now my cut quality is good, but i know there's always room for improvement. |
Everyone should keep in mind that the voltage has a lot of varying factors, and may not be the same at different locations across the country, so don't trust someone else's values to be perfect. Same goes for material, be it hot rolled, cold rolled, P&O, etc. the cut speed and amperage could vary.
That being said, around the shop we do a lot of 1/8" and 3/16". With a Cutmaster 2 series (82, 102, 152, A60, A80, A120) 1/8" 40 amps @ 85 inches per minute @ 106-111 arc volts 3/16" 40 amps @ 50-55 inches per minute 3/16" 60 amps @ 80 inches per minute @ 110-120 arc volts. |
Member # 26393
I also notice as the electrode burns away, the torch drops a bit to keep the same voltage height.. so I have to adjust voltage for the height control periodically while cutting..
#6 (permalink) | |
Lincoln Cutting
Member # 152411
Some shops will find a voltage that they can set the machine at and cut all day regardless of what the electrode wear is. They may have a bit of cleanup throughout the day but their operators have less to worry about. On the other end of the spectrum we have some customers who will adjust frequently and this time spent gives great cuts throughout the day. It's all about the specifications of the parts cut and the need for simplicity. -Jack
Torchmate Technical Support - 6 AM to 4 PM PST 866-571-1066 x3 support@torchmate.com |
Member # 147477
Well I finally got my machine up and running. I had a chance to cut some 14G with my powermax 45 @ 30 amps and 100 inches per minute. I found that some of the parts would actually weld themselves back together making them difficult to remove once finished. Any one have something similiar.
Gord
Miller 211 w/Autoset, Hypertherm Powermax 45 w/machine torch, Torchmate 2x2 CNC w/plate marker and laser crosshairs |
#8 (permalink) | |
Member # 29097
"Those who make peaceful revolution impossible will make violent revolution inevitable." SunDog Quarter Horses |
#9 (permalink) | |
Member # 15076
Is it welding itself back together or not cutting all the way through? |
#10 (permalink) | |
Member # 84965
Maybe try cutting at 40a if you want 100 IPM. Either way you need more power to go faster. Or go slower with 30a. Last edited by xr8ed; 04-27-2010 at 12:06 PM. |
Member # 147477
I'm trying to run the line speed test but can't seem to open the file. Do I open it right in the driver software or in the torchmate cad?
g
#14 (permalink) |
Member # 147477
perfect thank you I will give that i try
