Member # 29097
Support slat spacing
After looking at the table builds on here I see what looks like a large range of slat spacing. Some look like 1" and others are far greater. What are the things that you considered when setting up the slat spacing and why did you go the route you did?
"Those who make peaceful revolution impossible will make violent revolution inevitable." SunDog Quarter Horses |
The biggest thing is considering the size of the parts you are going to cut, and the "tip-up's" that could potentially grab the torch head.
We typically go with 3" on our larger machines with AVHC, because the torch actually retracts 3" in between cuts. If the slats are closer together, you can cut smaller parts without having them tip up. The closer they are together, you'll have more so you can also make them skinnier. |
Member # 29097
I am going to be cutting a lot of small stuff so I will probably go with 1" spacing on my slats. I also decided not to go with a downdraft table but a water table instead. There are to many benefits to a water table not to go that route.
Boyd Welding LLC
Member # 141166
Ours is 3.5" apart. the slats also have an arc.
Dave Boyd / CEO www.boydwelding.com PHONE:352-447-2405 TOLL FREE: 877-270-3576 FAX 352-447-2403 EMAIL: daveboyd@boydwelding.com |
Member # 66858
Laser guy here again:
What I have done in several machines is notch the end of the slat so that when they are inverted they drop another inch. Then I make smaller sacraficial risers for the jobs that incolve lots of close quarter high power cutting. The small risers sit on top of the main slats and make up the height difference.
Member Deep Woods Extreme 4X4 Club Of Southern NH. |
#6 (permalink) | |
Member # 29097
#7 (permalink) | |
Member # 159031
I haven't built my table yet but I can see problems with the cross bar interfering with material longer than 24 inches if I want to index on a longer table. |
#8 (permalink) | |
Member # 29097
