Member # 118370
Not to be too ignorant, but, why wouldn't you make up a jig to support the strips and simply burn them on the CNC Plasma table?
Bobbed CJ-8, TJ/RE/AiRock, 6.0L, 4L65e, Atlas-II, PSC Ram Assist Hi-Steer, HP D60 ARB F/R, WTF? |
Member # 159031
The issue I find with either milled or plasma cut slots is the radius of the mill and or the kerf angle at the bottom of the slot; either one means the rectangular slat is making contact with a circle instead of a flat surface, Not an issue when everything is new, however as weight is applied to the slat it will dig into the circle or kerf angle and you will have an uneven slat. Very minor and maybe it won't ever happen, but others have made simplier slat holders using just square tubing support rails with square tubing spacers, simple but effective.
I have a mill and could make them but it would be easier to use simpler methods. Not as nice looking as the milled ones but functionable. |
#6 (permalink) | |
I don't see any reason not to Plasma cut the slat supports if done with the "thermometer" bubble at the bottom of the slot. |
