AVHC Acting up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2010, 01:11 PM   #1 (permalink)
Liquid Iron Ind.
Timmay's Avatar
Member # 52894
AVHC Acting up
Of course this happens when tech support isn't available and I absolutely need the machine running.
My AVHC seems to have had a parameter changed somewhere which tells it to fire in the air. Instead of jogging down, touching the part, raising to the pierce height, and then firing, it is jogging up, hitting the stop, then firing in the air ~8" above the workpiece.
It will only do this every other time. If I stop the program after it fires in the air, it will jog down and pierce normally. Then at the next pierce position it will fire in the air again. If I stop the program and restart again, it pierces normally.
This is driving me nuts and I know it's something stupid. Any ideas? I need this machine to finish team Quadratec's pro-mod for next weekend's Werock event...
Thanks in advance...
Tim Diekmann
Liquid Iron Industries, LLC
tim@liquidironindustries.com
http://www.liquidironindustries.com/
(856)-336-2639
https://www.facebook.com/liquidironindustries
Molten Motorsports #4343 "Fred"
Timmay is offline   Reply With Quote
Old 05-15-2010, 07:42 PM   #2 (permalink)
BESRK's Avatar
Member # 26393
Is the screw/slider system clean? When mine gets dirty, it'll provide enough resistance to trick the AVHC into thinking it's hit the plate... triggering the torch in the air. A quick cleaning usually does the trick. I also went to the setup screen on the AVHC and bumped the torque setting up a couple pounds (I think I went from 15 to 17). Hasn't done it for the past couple weeks.
Little CJ5 on 35s.
BESRK is offline   Reply With Quote
Old 05-16-2010, 08:14 AM   #3 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
Ditto... The fact that it works correctly sometimes....
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 05-16-2010, 08:24 AM   #4 (permalink)
AKA Topper
Tuffjarhed's Avatar
Member # 14368
Also check the torque on it, I had mine set too low, causing a similar reaction. Make sure it is 15.
NEVER FORGET 9/11!!!!!
Hung like Einstein, smart as a horse.
Tuffjarhed is offline   Reply With Quote
Old 05-16-2010, 01:58 PM   #5 (permalink)
Liquid Iron Ind.
Timmay's Avatar
Member # 52894
Nope, that isn't the issue. I've had that problem in the past so i've made a habit of regularly cleaning it.
The torch literally just goes in the wrong direction and bottoms out on the stop. This tricks the AVHC into thinking it is touching the plate and then it fires in the air. Maybe I need to take video. It does what it's supposed to do, just in the wrong direction. Almost like the AVHC motor is getting reverse polarity every other pierce.
Tim Diekmann
(856)-336-2639
Old 05-16-2010, 07:15 PM   #6 (permalink)
Torchmate's Avatar
Member # 98865
Have you turned up the touch torque and had the same thing keep happen?
The symptoms you are describing point to binding. Worst case, turn it off, wire the plasma cutter direct to the electronics bypassing the avhc until tomorrow when tech is back in the office. That way you can run manually for the time being.
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 05-17-2010, 12:17 PM   #7 (permalink)
Member # 115338
Check to see if your off delay is long enough, under Configuration, Programming and M-code Definitions for Plasma Off increase your off delay to 1.5 seconds. Also with the cut light off, press the Aux button on the driver software and Press the Plasma button to turn it on and off to see if the height control comes down and up every time if it does not then that would tell you the slides need to be cleaned on the lifter station.
Dnmeistr is offline   Reply With Quote
Old 05-17-2010, 01:05 PM   #8 (permalink)
Member # 84593
Sometimes this small upward motion is misinterpreted as the motor heading "backwords" to sense the material, when it is usually just retracting to the pierce height after instantly sensing enough resistance. If you set the Pierce height and Init cut height to 0, does it still bump up?
If it does, reprogram the motor through the "Factory Menu", which is accessible by powering down the unit, and holding the Down + OK button while powering it on. This may solve any programming issues.
Then the typicaly set touch torque needs to be above 18, and a smooth operating lifter station.
Let me know if you have any questions on it.
HardcorewannabeXJ is offline   Reply With Quote
Old 05-18-2010, 09:35 AM   #9 (permalink)
Member # 50132
I have had the same issue, knew it was not from dirt. also bumped my tourque a couple of pounds still same issues. Finally found that it had a very slight bind issue. backed allen bolts off a 1/2 turn and its now gone.
bigS-dime is offline   Reply With Quote
Old 05-19-2010, 01:39 AM   #10 (permalink)
Member # 46427
I had the same problem for a while.... the tech keep getting stumped... with your unknowing help I have now fixed it. All I have to say is thanks guys.
Yellowcard is offline   Reply With Quote
Old 05-19-2010, 07:22 AM   #11 (permalink)
A.A.I.
Member # 157433
I had the same problem with one of the motors for the gantry drive. The motor would change directions each time I attempted to jog the gantry, even if I continued to jog it in the same direction as the last attmept. I found that the ground wire, in the six barrel connector that plugs into the conversion box was not seated fully. Once I pushed the wire all the way in everything was fine.
roscoe1 is offline   Reply With Quote
