Aluminum frame water table? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2010, 12:02 PM   #1 (permalink)
Member # 159842
Was wondering if there would be any drawbacks to using aluminum as a frame for my water table. I’m thinking of making one, kinda like “jeepsRcool”. The outside frame and legs would be 4X4X1/16 square tubing. Along the inside would be aluminum angle 3X2x1/4 with 1” slots along the 3” side for the mild steel flat bar and the 2” part as the bottom. I was going to rtv in a sheet of mild for the bottom. The entire cutting surface would still be steel. Thoughts?
V/R
Mike
abnaasefmb is offline   Reply With Quote
Old 05-17-2010, 01:19 PM   #2 (permalink)
Member # 84593
As long as it's strong enough and the aluminum won't ever be cut by the plasma I don't see any reason why not, the corrosion resistance is a bonus. If you have the aluminum and the ability to fabricate with it is the only reason I'd see doing one this way instead of welding up a mild steel one though.
HardcorewannabeXJ is offline   Reply With Quote
Old 05-17-2010, 03:04 PM   #3 (permalink)
Member # 159842
supplies to make a 6x2 table with a indexable 4x2 cutting area will run about 450-500, does that seem bad? seems like the mild would be about the same price. thanks for the input.
your avatar creeps me out.
V/R
Mike
