Low Budget Water Table Build for my 2x2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-24-2010, 01:02 PM   #1 (permalink)
Member # 151021
Send a message via AIM to MikeRenz
i'm sure i'm not the only one that spent their entire allowance on the 2x2, and don't want to pay top dollar to build a water table. I've drooled over all the beautiful tables built with hundreds of dollars of brand new metal.....well i refuse to partake in that nonsense!
So, what do you do when you have $0 that you'd like to spend on water table construction? Well you dumpster dive of course...and look in every last storage closet you have access to.
Thankfully we came across a lot of 2x6 box beam. I'm not sure what it was used for, but i know what it's about to become.
After hours of grinding, cutting, welding....we're left with this:
The front lip will house the keyboard/mouse/dual 17" lcds. The plasma/computer/controller/wiring will all be beneath the water on a shelf. No worries, it will all be shielded from water in case of a mishap. We'll also be adding some sort of splash shield between the monitors and the cutter.
The cutter isn't in the pic, but its a Cutmaster 82 which has a pretty small footprint, so we should have quite a bit of space under the table on the shelf for storing the router/z-axis when not in use, consumables, metal scraps..and whatever else we see fit to stow there.
Only a few things left to do it strip the pimp orange and give it a nice coat of black. Then no one will be wiser as to the age of the material. Plus we still have to figure out the slat supports. Most likely will just use some angle iron with notches cut in it. Still trying to figure out the cheapest viable option for the slats. The table will be on casters so that we can push it in the corner when not in use.
Otherwise, just another run of the mill water table....only total $ spent is $0.00 (not including welding gas/consumables/power anyway...). I can't wait to start cutting on it to see the difference in mess/smoke. Shopvaccing after every time you use the machine gets old quickly.
MikeRenz is offline   Reply With Quote
Old 05-24-2010, 01:16 PM   #2 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Looks great! Would you mind sharing your inside dimensions for the water part?
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax
Classic Rig: '88 FJ62, 100% stock
In the weeds waiting for resurrection: '94 FZJ80, 33s, locked
Arya Ebrahimi is offline   Reply With Quote
Old 05-24-2010, 01:20 PM   #3 (permalink)
Member # 151021
thanks, i can measure it either friday or sunday when i'm at the shop next
Old 05-24-2010, 02:20 PM   #4 (permalink)
Member # 157182
Its 32" wide by just over 4' long by 5" deep.. The box beam is actually 2"x5" not 2"x6"..
32" wide works well because if we end up getting slats 8' long we can just cut them twice to get just under 32"..
Also, we have a little more than $0 into it. I had to buy the 3/4" ball valve, some pipe, and 2 90s for the drain..
mattjw76 is offline   Reply With Quote
Old 05-24-2010, 08:15 PM   #5 (permalink)
Member # 157475
Looks like old pallet racking
Brewzur is offline   Reply With Quote
Old 05-24-2010, 11:43 PM   #6 (permalink)
Member # 14396
looks nice, once you get the thing painted it will look killer!
Pendleton Racing and Fab.
jeeperjer is offline   Reply With Quote
Old 05-25-2010, 04:20 AM   #7 (permalink)
Member # 157182
Yep, thats exactly what it is. My buddy's dad has a mountain of it in the woods out behind his house..
Old 05-25-2010, 06:08 AM   #8 (permalink)
Member # 159031
Where there is a will, there is always a way, I couldn't help but notice that you have the same engine hoist I have, tucked in your corner. It never ceases to amaze me how many people have the same stuff in their shops/garages. Oh well great minds think a like.
ron678 is offline   Reply With Quote
Old 05-25-2010, 01:04 PM   #9 (permalink)
Member # 157182
Caster wheels and table surfaces added..
Also water tested. Its had water in it for ~6 hours now and there is no sign of a leak.
So the total water bed depth is 5". I was thinking of using 3" slats. That would allow me to have 1" of water under the slats and keep the water level 1" below the sides of the table to be even with the top of the slats. Is this the right way to do it?
Old 05-25-2010, 02:40 PM   #10 (permalink)
Member # 84593
Pretty much, with 1" of border around the top of the water table, you'll lose a lot less water then having them even with the top of the slats. However cutting pieces of material larger then the table could be an issue.
HardcorewannabeXJ is offline   Reply With Quote
Old 05-25-2010, 03:16 PM   #11 (permalink)
SoundManCO's Avatar
Member # 29097
I am working on a straight edge with magnets on it to set on the sides to help keep water in on mine when cutting small pieces that are not sticking out the side. If my slats went the other way the water getting out would be less of an issue but my slats would be longer (more material). My slats are flush and this works great for cutting larger material.
"Those who make peaceful revolution impossible will make violent revolution inevitable."
SunDog Quarter Horses
SoundManCO is offline   Reply With Quote
Old 06-02-2010, 02:39 PM   #12 (permalink)
Member # 157182
I made some more progress on the table. I decided to weld the outer edge of the 1/8" mild bottom to the rails today. Not to bad for my first time tigging mild steel:
I also played around some with how the slots will get mounted. This is probably how they will go:
Old 06-05-2010, 01:55 PM   #13 (permalink)
Member # 157182
Today I cut/ground a bunch of slat supports:
Some of which got welded into place:
Its getting close!!
Old 06-05-2010, 06:42 PM   #14 (permalink)
BLKBOB's Avatar
Member # 147477
Hey that slat support idea looks familiar looks good man congrats. Once you get up and running you will love it.
Gordo
Miller 211 w/Autoset, Hypertherm Powermax 45 w/machine torch, Torchmate 2x2 CNC w/plate marker and laser crosshairs
BLKBOB is offline   Reply With Quote
Old 06-06-2010, 12:15 AM   #15 (permalink)
Member # 118007
gives me ideas for when I get a job. I am gonna save these pics with the dimensions. Cool build.
glamisrnr is offline   Reply With Quote
Old 06-07-2010, 01:35 PM   #16 (permalink)
Member # 157182
Its finally ready for paint..
Old 06-08-2010, 09:43 AM   #17 (permalink)
Member # 157182
All primered..
I hope to paint it tonight..
Old 06-08-2010, 02:20 PM   #18 (permalink)
Member # 7876
Do the pics work for anyone else? Only the first pic in the first post is working for me, the rest are red x's.
Old 06-08-2010, 05:01 PM   #19 (permalink)
Member # 151021
they all work for me. The first picture is hosted on a different server...maybe you just can't get to the other pics momentarily.
Old 06-08-2010, 08:46 PM   #20 (permalink)
Member # 14396
looking good! and i see them all fine...
Old 06-09-2010, 02:26 PM   #21 (permalink)
Member # 157182
Old 06-11-2010, 05:57 AM   #22 (permalink)
Member # 157182
Finally!!!
Old 06-12-2010, 12:27 AM   #23 (permalink)
Member # 84965
Looks bitchen, what about a splash shield behind the monitors?
xr8ed is offline   Reply With Quote
Old 06-12-2010, 08:22 AM   #24 (permalink)
Member # 157182
I think I am going to run it first and see how much it actually splashes. I made this stand for the monitors to give more room for the keyboard/mouse. If the water splashes up beyond this stand then I will make a plexi-glass shield.
-Matt
Old 06-12-2010, 07:43 PM   #25 (permalink)
Member # 157182
Other than some cable cleanup, possibly flipping the gantry around, and filling it with water its done!!
You can see the protective hood I made for the plasma cutter in this pic. I'm sure this table will never leak but I don't want to take any chances..
