#1 (permalink) | |
Primo Luchador
Member # 62501
Loses shape
Attached is a photo of a circle cut into 316 Stainless. I have marked the beginning and end of the cut. What causes this mishape? The tip was blown out, so is it just the bad tip? With power to my motors the gantry does not move when pushed, so the gears are tight. Is there a second factor to this, cus I get cuts like this every once in a while.
Any Seven Offroad We cut, bend and weld metal to make what you want. Quote:
Member # 98865
It is mechanical. Something is slipping or binding. I would bet money on it. The only other explanation would be that the machine is binding. Run it with the plasma cutter turned off. You will hear it if a motor loses position due to binding. Which model do you have?
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/ |
Member # 98865
Hey, I just thought of something else. Maybe you have a lead-in or lead-out that looks like it is not there unless you zoom way in. I just noticed that you don't have it starting and ending at the same point.
WWW.TORCHMATE.COM We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings. Buy your consumables here! www.torchmatestore.com Torchmate Racing Homepage: www.torchmateracing.com Torchmate CNC Forum here: http://www.pirate4x4.com/forum/forumdisplay.php?f=125 |
#5 (permalink) | ||
Primo Luchador
Member # 62501
It's a Torchmate 3.
Member # 98865
I think that the best thing is to have the guys in tech work with you to solve it over the phone. We can go back and forth in here, but it is a lot easier to walk you through some tests to nail down the problem. Check both sides of the gantry to make sure that both motors have power to them. If one of the x axis drives is dead then you would most likely not be able to push the gantry, but the one motor would be having to drag the other. It does look like only one axis by the way that circle cut great 3/4 of the way around.
#7 (permalink) | |
Primo Luchador
Member # 62501
I'll give the motors a check and see how it goes from there. Thanks for the support, your customer service is incredible!
Whatever axis is moving left to right in that photo is slipping on either the large pulley, small pulley, or the belt is loose. This is if the gear is fully engaged in the gear rack on both sides of the table all the way across the length of travel.
#9 (permalink) | |
Primo Luchador
Member # 62501
gear is fully engaged, no pullies. Like I said, happens once in awhile.
#11 (permalink) | |
Primo Luchador
Member # 62501
what method do you use to set the backlash? I was told not to insert a piece of paper between the gear and rail by their tech support.
I'm still blowing through tips way too fast. The AHVC will occassionally just start pulling the torch away while it's firing and the software will continue to move, thinking it's cutting. I read on hear to check both the torque (mine is set at 15 or 17) and make sure the gear is clean.
#12 (permalink) | |
Desert Fab Motorsports 480 288-4213 480-980-2681 Todd |
#13 (permalink) |
The only problem resulting from too tight of gear rack would be rapid travel position loss. This would generally be cutting the correct size pieces in the wrong area on the table.
Flat spots on circles that is Not program caused, would be related to the motor motions not making it from the spindle of the motor, to the gear rack on the table. This is where you should be looking. If the motor is making flat spots in the same spot on the same program in different areas in the table, my assumption would be it's the program itself. To test that theory, you could change the axis on the table, or switch the motor cables to make the X become the Y and vice versa. If the problem stays in the same spot on the program, then it's a program fault. If the problem moves to a different spot on the program, but is still in the same axis that the problem was previously, it's a physical problem on the table. -Mike |
#14 (permalink) |
Bring the Fail
Member # 14085
Also, check your steel rails on the X-axis, my rails were not perfectly flat and causing the gear mesh to be too tight or too loose, causing oblong holes in some cuts. I had to drill additional mounting holes in between the factory mounting holes to get the rails to flatten out. Check you gear track with a micrometer at each mounting point; this was another item that was not flat either.
