powermax 45 question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2010, 12:59 PM   #1 (permalink)
Member # 156241
I was doing some dry runs but allowing my plasma to come on just to see if my compressor could keep up with it. The power unit pressure LED is telling me all is good, staying right in the middle where it should be, but the torch wont stay like for the whole program. All I'm running is the line speed test as my dry run program. My question is- do I need to have the earth clamp attached to the table or some other material for the torch to stay lit? Dont understand why it wont stay lit if the air is good and it has enough power. As I'm still learning I thought I would just cut some air and not burn up valuable material, dont know if this a problem for a plasma or not.
cnc4me is offline   Reply With Quote
Old 05-31-2010, 01:45 PM   #2 (permalink)
KacksterK5's Avatar
Member # 5851
Yup, ground has to be on and cutting something to stay lit.
02 Chevy 2500 HD Tow Rig
KacksterK5 is offline   Reply With Quote
Old 05-31-2010, 03:18 PM   #3 (permalink)
Member # 156241
Ah ok thanks. One more hurdle behind me.
Old 06-02-2010, 04:34 AM   #4 (permalink)
Member # 145912
Firing the torch without the work clamp attached to the workpiece will only allow the pilot arc to activate....and if it senses no arc attachment it will time out and shut the arc off. Excess firing of the pilot arc will wear the nozzle orifice very rapidly, and is not recommended.
Jim
jimcolt is offline   Reply With Quote
