Yukon Gear and Axle
Member # 35700
little black box
I have a TM3 table with Oxy and plate marker attachment.
My OXY doesn't work - cut or the solenoid. On the back of the 2 plug box, there is a connector. That connector only has 3 wires, all in the bottom - red, black and white I think. On the back of the USB driver box there is 3 sets of cables coming out of the output connector - 1, 3 and 5. Plasma, Plate Marker and OXY. However, if I unplug the one for the plate marker and plug in the other for OXY, then it works, but my plate marker doesn't work (I also swap the plate marker for OXY plugs on the output, so both are always using #1, for example). It seems to me that both connectors need to be made into one. So do I just pull the pins out of the one connector and put them into the other with the plate marker - following the coloring on the row below, just above?
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
Lincoln Cutting
Member # 152411
You will need to test each output line. From what you described it sounds like you have a triple interface cable. Each of those cables contain two output lines. You will want to go to Configuration -> I/O -> Output lines. In this menu simply type in for lines 1-6 the numbers 1-6. Then in your AUX tab lines 1-6 can be activated. Once you determine which line is activating the solenoid you can configure the software to run each tool. Please refer to this guide for screenshots of the procedure.
Torchmate Support Site -Jack
Torchmate Technical Support - 6 AM to 4 PM PST 866-571-1066 x3 support@torchmate.com |
#3 (permalink) | |
Yukon Gear and Axle
Member # 35700
I did try the 1-9 (actually) thing, but I think I did that and swapped the connector, rather than seeing if it would work the other way first. but I will try that when I get to the shop today! Makes sense
Yukon Gear and Axle
Member # 35700
That did it! The connector going to the plasma box looks like it would be outputs 1 and 2 and for the second box is 3 and 4.
