Member # 163562
the website for torchmate says you can use it for milling and it's much cheaper than the mills i've seen which run like 10k. It says you can add the z axis but I'm not sure if anyone has any experience with it. does anyone have any mill suggestions?
from the torchmate website: it is designed to bring CNC Plasma Cutting, CNC Routing, CNC Drilling, CNC Milling and CNC Engraving to you in one tight little package starting at less than $2,000. |
The 2x2 can do light aluminum work, it's all about keeping the bit cool. It's a 3 axis cnc mill and if you can design and program 3d work, I don't see any reason why not. Keep in mind if you plan on doing production work to make 10,000 iPhone cases, the 2x2 was not designed to do that, $10k + cnc mills are.
Member # 162029
Location: Central New York...The state not the friggin city
I'm using my torchmate 2x2 as a router only. It's doing some great work in 3d just with the z axis ratio you have to keep your speeds down. I try to keep my cutting feed to about 10 ipm on the z axis because it just doesn't have much down force. This is in wood and plastics. I actually lost a few steps today on a long project. Over 100 deg in the shop on an hr and a half run, not thinking to add a little extra oil on the axis it probably lost 1/32 of an inch. Wasn't an issue with the type of project. I'm going to be trying my hand at milling brass for some trigger guards on my rifle stocks when i get back to them. It's going to be a while, maybe three months or more. I would say for both brass or aluminum, some sort of sprayer for coolant would be a good idea.
