Finecut recommended height? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-08-2010, 07:47 AM   #1 (permalink)
Bring the Fail
YuNiT's Avatar
Member # 14085
Machine:
Hypertherm 1000g3
Table:
Torchmate 3 with AVHC
Tip:
FineCut, amperage set at 40
Material:
10 gauge stainless
Settings:
Initial cut height = .01
Pierce height = .03
Pierce delay = .2
Sensing Delay = .5
Torque = 15
Since the recommended height of normal consumables is .12" from Torchmate, compared to Hypertherm's recommend .0625" for mild steel. What height settings are you using with the FineCut consumables? I tried using Hypertherm's settings of .01" for stainless and by the second piece, the nozzle was fused closed.
Thanks.
Pete
RIGHTCOAST4x4
Custom Tshirts & Vinyl
YuNiT is offline   Reply With Quote
Old 07-08-2010, 07:51 AM   #2 (permalink)
Member # 84593
Directly from the Hypertherm 1000 Operators Manual for Fine Cut consumables, they recommend .08" for mild steel and .01" for stainless. For the pierce height and initial cut height I would recommend setting them between .05 and .03, as there may be about .02" error with the values on the avhc display based on the material flexing and backlash being accounted for.
HardcorewannabeXJ is offline   Reply With Quote
