Member # 107883
2x2 Gear Ratio?
With the standard setup file it is setup with
2a stepper 2 in step mode 200 in motor res and 1.64 in gear ratio(stuff comes out small) change to 2 (stuff is perfect) Well If I try to cut a 5in circle it comes out as a 4 inch circle, but if I change the gear ratio to 2, it comes out perfect..... Is 2 the right value for the 2x2 machine?
[URL=http://www.pirate4x4.com/forum/showthread.php?t=871614]Plasma Table Build / Torchmate 2x2[/URL] Chevy Build with 5TonRocks......Coming Soon.....:flipoff2: |
Yukon Gear and Axle
Member # 35700
No idea on the 2x2, but when I setup my TM3, I had to make that adjustment. And I did it by going from one end of the table to the other, measuring and seeing if it traveled what I measured. If not, I changed the setting until it matched. I'm assuming its the same thing on the 2x2?
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
Member # 107883
Yeah i just figured the Included setup file would have been right, but oh well, now I have one under sized rim guard.....
Ill call it a proof of concept......
Yukon Gear and Axle
Member # 35700
On mine, the included file was generic and part of the instructiosn were to set it up correctly :shrug:
Member # 115338
Gear ratio should be 1 and screw thread is 2 for both x and y. There is a setup file on the TM 2x2 CD under the folder Setup Files, whether you are using it for plasma or as a router. Copy that file to the C:/Torchmate Data/Torchmate 3/Setup directory and open it in the TM3 driver software by clicking on File and Open Setup and verify the gear ratio and screw thread are 1 and 2.
The installation is default for all of the machines, as the software is universal. The instructions have you open the 2x2 setup file off the CD with the correct ratio. Last edited by HardcorewannabeXJ; 07-12-2010 at 09:53 AM. |
