Cutmaster 39 Hook Up to 2 x 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-19-2010, 08:37 AM   #1 (permalink)
Member # 163688
I just spoke to thermal dynamics, and they said to tap into wires 12 and 13 to hook up to me 2 x2. Does the plug come apart, or do I need to strip a spot and solder the wires into? Does the torch trigger need to be tied down? They also siad that you could also use the ATC remote interface adapter, part 7-3474. Has any one used this?
43GPW is offline   Reply With Quote
Old 07-19-2010, 10:41 AM   #2 (permalink)
Member # 84593
Just use some splice connectors inside of the unit behind the plug to hook onto those wires. You do not have to tie the trigger down, and the trigger will still work as normal for hand cutting. The ATC Adapter would work, but not necessarily worth the cost.
HardcorewannabeXJ is offline   Reply With Quote
