Useful threads, How-to's and other information - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2011, 03:18 PM   #1 (permalink)
SoundManCO's Avatar
Member # 29097
There is so much good information in this section of the forum and it is getting hard to find it all. A single thread that is a sticky with links to the useful information seems to be needed. I did a few how-to's and there are a few others that should be linked and then there are some set-up and configuration threads that should be in here as well. I figured I would get the ball rolling on this and then a mod can stick it to the top of the forum. This is just a start so ad the links you find help you the most.
How do I or how-to's;
Trace an image in TM-CAD-Lite
CAD-Lite, Tool Paths
CAD-Lite, weld on bead locks
CAD-Lite tapered bracket (one way to do it)
Welding and alignment tools in Torchmate CAD-Lite
how to curve text
CAD-Lite - Cutting and rounding corners
Video walk through of making a flange, it is buried in the thread but worth watching.
Common Line Cutting Walk Through and how to index a cut
Bridging Letters Walk Through
Adding fonts to CAD-Lite
How to recover a drawing from a tool path
When you import in a picture from AutoCAD or Solidworks they come in broken, here is the fix.
What are all the Keyboard Shortcuts
Controlling Start points and lead in locations by MQYJ
Set up information
2x2 alignment guide
Keep track of your settings for different materials. A great spreadsheet to use as a reference by Wayne.
Operation
easiest way to re-cut a miss-cut
Figuring out where you are....
AVHC Doesn't adjust when cutting AVHC explained in detail, post #10
How do I figure out a cost estimate. Awesome spreadsheet in here
Wireless control for your Torchmate
Homemade Platemarker
Who has a Torchmate close to me? If you want to see one in action or get a job done take a look to see who is close to you.
Torchmate's tech support site
Torchmate CAD 7/8 support
Please post links to threads that have helped you get going, get set up or the things that you have found useful in this forum and I will ad the links so there is only one place to go to find these things. I searched for the cut/charge sheet thread and came up empty. It should be in here for sure IMO.
"Those who make peaceful revolution impossible will make violent revolution inevitable."
SunDog Quarter Horses
SoundManCO is offline   Reply With Quote
Old 01-21-2011, 03:52 PM   #2 (permalink)
Torchmate's Avatar
Member # 98865
Thanks SoundMan! I stuck the thread at the top. I will most likely delete any posts on this thread other than actual "how to" links. Just a heads up, if anyone has questions about these particular items, post up questions in the forum as a new thread rather than cluttering this thread with them.
WWW.TORCHMATE.COM
We are hiring! Email your resume to our Human Resources Manager at cnichols@torchmate.com and ask about openings.
Buy your consumables here! www.torchmatestore.com
Torchmate Racing Homepage: www.torchmateracing.com
Torchmate CNC Forum here: /forum/125-torchmate-cnc-forum/
Torchmate is offline   Reply With Quote
Old 09-16-2012, 04:17 PM   #3 (permalink)
Member # 123339
how bout one on the auto trace in full cad?
kbenz is offline   Reply With Quote
Old 04-26-2013, 07:01 AM   #4 (permalink)
SoundManCO's Avatar
Member # 29097
If I had the full version CAD I would do it. If anyone else has it and wants to post a walk through I will link it in here.
