HF Compressed Air Dryer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2011, 11:08 AM   #1 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
Before I buy this, wanted to run it by you guys. HF has a coupon code ( GIFT20 ) for 20% off on online orders. That means I can get this for 80 off.
Shall I pick this up? or are there better options? I have a motorguard filter, but I think I still have moisture getting through.
http://www.harborfreight.com/compres...yer-40211.html
jdh239 is offline   Reply With Quote
Old 03-17-2011, 01:39 PM   #2 (permalink)
Member # 163388
I've heard that this is one of the few things from Harbor Freight that are a decent tool. I have been watching the samething with the same cupon. My local store doesn't ever seem to have them.
SomeGuyFromOlympia is offline   Reply With Quote
Old 03-17-2011, 03:42 PM   #3 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
My local store doesn't have them either... you have to order online (and it is on backorder)
Old 03-18-2011, 11:27 AM   #4 (permalink)
Yukon Gear and Axle
waynehartwig's Avatar
Member # 35700
I asked around and those with them liked it, so I bought one and so far I'm diggin' it.... Right now they have 20% off and a free shipping deal going. Not sure if you can use both together or not...????
#4502 "The Rental", Team Yukon Gear and Axle
Good Seller/Buyer List!
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
10% PIRATE COUPON CODE: pirate4x4
Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote
Old 03-18-2011, 02:10 PM   #5 (permalink)
Member # 163388
what I have seen
the cupon for 20% off if for in store purchases
of course my store never has it in there. It was in the fine print.
Old 03-18-2011, 02:14 PM   #6 (permalink)
Yukon Gear and Axle
Member # 35700
Originally Posted by SomeGuyFromOlympia View Post
what I have seen
Online code GIFT20
According to my local HF those are internet only...
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 03-18-2011, 03:27 PM   #7 (permalink)
Member # 163388
Originally Posted by waynehartwig View Post
Online code GIFT20
then that explains why I have never seen one in there!
Old 03-18-2011, 03:44 PM   #8 (permalink)
I make websites!
Member # 12429
Everything at HF is going up in price when I got that 2 years ago it was around 280$ with inside track club. Regularly $329. I would snatch it up with the 20% for sure it will only go up now.
My 4x4 Blog
Rockwell axles too!
Todd W is offline   Reply With Quote
Old 03-18-2011, 04:01 PM   #9 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
Online code GIFT20
My HF said they would honor the online code if I print off the email
Old 03-18-2011, 08:24 PM   #10 (permalink)
Yukon Gear and Axle
Member # 35700
My HF doesn't carry it or maybe they would?
I tested mine out pretty good today... Input air temp 284*, output 50*. I hooked it up directly to the compressor, between the compressor and the tank, then I let the compressor run for 30-40 minutes with the tank valve open and around 90-100 psi the whole time. The water/oil seperator built in accumulated about 1.5" of water in the bottom of it during this time. It's about 3"? OD.
Next i want to run the power off the air tank switch. So that when the tank kicks the compressor on/off, it also turns the refrigerated dryer on/off. No sense in making it run the entire time
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 03-18-2011, 09:22 PM   #11 (permalink)
jatepper's Avatar
Member # 185144
Yep, I just bought one with the GIFT20 code. You can indeed use the code and the free shipping, so pretty good deal IMO. I too have heard nothing but good things about this product.
jatepper is offline   Reply With Quote
Old 03-18-2011, 09:28 PM   #12 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
I don't think it is carried in stores. My HF said they would have to order it, but they would have done it for me if I would have told them to.
Old 03-19-2011, 08:39 AM   #13 (permalink)
Yukon Gear and Axle
Member # 35700
Damn...That is a good deal... I only got the 20% off... But shipping was only $13... $363.04 to my door. $30 was sales tax...
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 03-23-2011, 09:35 AM   #14 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
GIFT20 no longer works. Try SPRING20 and still get 20% off until March 27
Old 03-23-2011, 09:33 PM   #15 (permalink)
Yukon Gear and Axle
Member # 35700
UPDATE:
If you buy this, there is a quick adjustment to be made - or at least on mine. I noticed that when the fan kicked on, the temp would drop considerably. So I adjusted the point where the fan kicks on. Now the air is still ~145*C going in, but the air going out is around 0-2*C, which is still low enough for the dew point and to pull water.
I ran my plasma on purge for an hour straight. The compressor cycled 4 or 5 times and the air temp never got higher than that 0-2*C...
Basically I set the fan low enough that it still cycles when the compressor is off. If you are looking at the control box (white box under the temp gauge), there are three phillips head screws. One in the top right, and then two in the middle'ish. The one on the left, was set at around 18, leave it. The one on the right was set at 10, I left it. The one on the top right was all the way down, so I simply raised it up to about the first white line.
Left side of the box is for the compressor. Right side is for the fan. The screw on the top right I'm assuming is a fine adjustment for the one below it. They both do the same thing, trigger the fan on/off setting....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 03-25-2011, 01:59 AM   #16 (permalink)
Member # 163388
any idea holong these are usually on bakorder?
I have ordered parts from Harbor Freight, excatly once before, it took so long that I already made my own replacement parts by the time they got to me
Old 03-25-2011, 10:11 PM   #17 (permalink)
jeffsullivan's Avatar
Member # 184217
just my $.02, but if you have a fridge in your garage keeping beer cold, run a copper line (ive seen pvc before too) in the fridge and back out, and there you have the same thing. i have a coil of 1/2" or so copper probably 25' long or so, coiled to about 16" round sitting next to the beer on the shelf. i will try to attach pics if you are interested. i have had very good luck with this system, and i run my table quite a bit.
Jeff Sullivan
J&M Custom Metal Fab
www.jmmetalfab.com
email:jandm@cni.net
360-751-5959
fax: 360-274-0210
www.facebook.com/JmCustomMetalFab
jeffsullivan is offline   Reply With Quote
Old 03-26-2011, 12:01 AM   #18 (permalink)
Member # 163388
I have sat there and stared at the coils of copper in Lowes with that same thought
Old 03-26-2011, 06:44 AM   #19 (permalink)
Member # 184217
ya its quite easy. i drilled a couple holes in the side of the fridge, ran the lines through, then filled them with spray foam. i works great. the only moisture i have gotten at the cutter is a couple times in the last year when i have ran my table pretty much non stop for 12 or so hours a day. i would guess more length of copper would help this, but like i said it has only happened a couple times in the last year. my table runs probably15-20 hours a week.
Jeff Sullivan
www.jmmetalfab.com
email:jandm@cni.net
360-751-5959
fax: 360-274-0210
Old 03-26-2011, 02:22 PM   #20 (permalink)
Member # 143830
I think I am going to convert one of my mini fridges here shortly, but I am going to try and put a drain at the bottom of the coil and maybe even stick some sort of fan in side the fridge to stir up the air.
comeoutswingin is offline   Reply With Quote
Old 04-21-2011, 02:58 PM   #21 (permalink)
Cold Creek Works
jdh239's Avatar
Member # 132992
Good for 3 days... here is another 20% off online coupon: 56267594
Enter that code on checkout.
Old 04-21-2011, 08:35 PM   #22 (permalink)
Yukon Gear and Axle
Member # 35700
I'm still loving mine... Works great, too. About everytime the compressor cycles, the drier shoots water out of it (auto drain)....
www.150Tunes.com
www.DiffsOnly.com
www.Jeeperman.com
Old 04-21-2011, 10:25 PM   #23 (permalink)
Member # 163388
are they still backordered?
Old 04-22-2011, 05:48 AM   #24 (permalink)
Member # 7876
Send a message via AIM to Arya Ebrahimi
Just an FYI, they sent out a 25% off coupon yesterday, good only on Easter Sunday.
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax
Classic Rig: '88 FJ62, 100% stock
In the weeds waiting for resurrection: '94 FZJ80, 33s, locked
Arya Ebrahimi is offline   Reply With Quote
Old 04-22-2011, 06:22 AM   #25 (permalink)
Member # 145912
Keep in mind that Craigslist is a great place to find used air dryers....every auto body shop has one....and when they go out of business, often the equipment is sold off cheap.
I have an industrial quality regenerating dessicant dryer for sale...if anyone is interested. It can handle up to 35 cfm air flow, has two large dessicant cylinders that the air flow alternates through.....when one gets saturated it switches to the second one automatically...and then uses a small flow of dry air from that one to dry the dessicant in the second cylinder. They sell for about $2k...I'll let this go for $250....plus shipping from NH.
I bought it (craigslist!) with another dryer and compressor that I'm planning to use in my shop...don't need this one!
Jim Colt
jimcolt is offline   Reply With Quote
