dross problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2011, 03:10 PM   #1 (permalink)
Member # 183090
dross problem
I am new at this so bare with me
I have a 2x2, powermax 600 with machine torch, good dry air. I am cutting 10 ga hot rolled steel 50 ipm at 45 amps. I have tried several heights, speeds and amps on the torch and I am getting to much dross, by to much I mean it looks like a very fine weld bead all the way around and this is at 50 and 45. I am using a dryer 30amp 220 volt outlet (temp). Could this be my problem?
three more dumb questions
1. where do I set arc voltage?
2. where do I adjust pierce delay?
3. will I be able to upgrade a 2x2 to a 4x2?
thanks in advance
ezongker is offline   Reply With Quote
Old 05-26-2011, 05:47 PM   #2 (permalink)
SRM
kyky777's Avatar
Member # 87853
I cut 10ga at 65ipm at 40 amps and it comes out flawless. powermax 1100 is my machine.
kyky777 is offline   Reply With Quote
Old 05-26-2011, 05:58 PM   #3 (permalink)
Terradon
harleyrdr1's Avatar
Member # 191332
I'm new here too. But I can answer this one for you. Yes you can. Torchmate now sells a 2x2 to 2x4 upgrade for about $500. I just bought my 2x2 and that's what they told me. =)
harleyrdr1 is offline   Reply With Quote
Old 05-29-2011, 06:49 AM   #4 (permalink)
SRM
kyky777's Avatar
Member # 87853
To adjust your pierce delay go into configuration, m-code definitions,And you will see the delay column in line 1 and highlight the number and set accordingly. This is all done in the driver program and not torchmate cad.
I will know more about arc voltage after wednesday when i pick up my new torchmate x 5x10!
Beat-It Fab chassis,tons,atlas,kings,347 ford powered!
Beat-It Fab
Dave's Off-road Outlet
Torchmate X 5x10 powermax 85, plate marker always burnin!
