Member # 194480
Air Compressor
Hey all, first off I want to say that I love the forum lots of very good info, researched the torchamte machines on here and made a purchase based on this section so keep up the good work.
I have a small TD plasma and am looking at getting HT Powermax 65 and am wonder how large of a compressor you all think I should get as well. The table is just a 2x4 so it really won't be running constantly and I don't want to throw money at something and do over kill on it. I currently have a craftsmen 33 gallon and was looking at perhaps an IR 60 or 80 gallon two stage...what do you guys think? I am doing light cutting like art type stuff and eventually what to have a side business sort of thing going....Thanks again! Last edited by nulbmanager; 07-17-2011 at 08:40 PM. |
#2 (permalink) | |
Member # 185144
Some people say they have to wait for 60 gallon compressors to "catch up". Just food for thought.
TM2 4x8 w/Integrated H20 table, AVTHC, Hypertherm Powermax 65 Semper Fi! 1999-2004 Last edited by jatepper; 07-17-2011 at 08:59 PM. |
Member # 3310
As already mentioned, the 33 gallon oil-less compressors won't work. I went with the Campbell Hausfeld 80 gallon from Lowes. I think it was around $800. It makes around 16 CFM if I remember correctly. Most plasma cutters use around 6-7 CFM. Even with the smaller 2x4 tables, you still go through a lot of air. I would definitely recommend the Campbell Hausfeld 80 gallon from Lowes.
#4 (permalink) | |
Yukon Gear and Axle
Member # 35700
It's also a 175 psi compressor, so it doesn't cycle as often as a 120 psi unit of the same would.
#4502 "The Rental", Team Yukon Gear and Axle Good Seller/Buyer List! www.150Tunes.com www.DiffsOnly.com www.Jeeperman.com 10% PIRATE COUPON CODE: pirate4x4 Special thanks to: Yukon Gear and Axle, Pace Oil Field Hauling, AllTech Motorsports, A1 Performance Transmissions and Converters, Randy's Racing Transmissions, Fountain Tire/Goodyear, Warn, Reid Racing, RuffStuff Specialties, BearTrax 4x4 OutFitters, Skinny Pedal Products, DiffsOnly.com, and 150Tunes.com |
#5 (permalink) | |
Member # 15076
I looked at regulators and it seemed like there was a pretty sharp increase in $$ when you step up over the 150psi range. |
#6 (permalink) | |
Yukon Gear and Axle
Member # 35700
My compressor goes into my HF dryer and then to my tank, and then from the tank into the M60 and out to tools. The HF dryer is only rated at 120 psi, iirc.... I honestly haven't seen any negative impact by doing this, though I was very hesitent in the beginning.
Member # 15076
That's something I never even thought of doing. I ran into issues with pretty much everything in my shop when I upped the compressor to the big 2-stage Quincy. I blew the guts out of the reg. at my plasma and caused all sorts of issues with cut quality. A main line regulator is my to do list but I don't live and die by my air tools so a good reg. at the plasma is all I have right now.
Member # 194708
I also just ordered a 2x4 TM and a Powermax 85 (can't wait til it gets here) and saw that my compressor is not enought. I found this one at Northern for $600 and will probably get it unless someone sees a problem with it.
Jason |
Member # 194480
Yeah I was thinking and leaning more towards the 80 gallon model and was just curious what you guys thought. As mentioned on here and in other threads about dryers and separators...are those really that necessary for running the plasma or are the filters good enough???
#10 (permalink) | |
Member # 15076
As far as the dryers being necessary. Every little bit helps and the dryer your air is at the torch, the longer the consumables will last. A lot of it depends on the relative humidity at your specific location, is your shop air conditioned?. If you are in a relatively dry climate and have anything else in your favor as far as drying the air in your shop, then a motor guard filter will probably be adequate. They are about $100 I think and have a replaceable filter element that is about 10 or 15. I've had mine installed for several months now and it has made a difference and I haven't replaced the element yet either. Another thing to remember, the smaller your compressor, the longer it will run continuously. The longer it runs the hotter it gets and the more moisture gets pumped into the system. If the compressor is larger and the heat is kept under control, the moisture is easier to deal with as well. There will always be some heat and moisture, it simply can't be helped. But the less your compressor has to strain the cooler it will stay. |
Member # 145912
Kind of depends how much you are planning to use the compressor. If it is just cutting a few brackets out two or three times daily...then you cna get a compressor that is close to the plasma specs for pressure and flow. If the plasma is 6.5 cfm@90 psi...then the minimum size compressor to keep the torch running will be one with the same spec.
My rule of thumb for anyone that cuts a nest of parts (say more than 10 parts at a time) is that the compressor should be spec'd at twice the flow requirements of the plasma.....so for a plasma that draws 6.5 cfm@ 90 psi...get a compressor that produces about 13cfm@90 psi. The bigger the tank...the better. And, while you are at it spend the $10 or so at Harbor Freight for their auto-drain.....other wise, if you have any of the same traits as me....your compressor tank will be half full of water in no time! I moved my compressor (which is an old Campbell Hausfeld 80 gallon tank with a newer 21 amp 1750rpm single phase motor and a Harbor Freight 13.8cfm replacement compressor head (usually $149 with free freight)) outside under the eves of my shop so it was quieter inside. My wife and her horses don't like it out there as well....but I can hear the classic rock on my stereo much better. Occasionally when the compressor has to start out there in the NH winter...often at below zero F temps....the 25 amp breaker trips. Every three to five years the chinese compressor pump fails....I order another replacement from HF and its good to go. How they can sell that compressor pump for $149 and pay the freight is beyond me. Jim |
#12 (permalink) |
Member # 194708
As of now it's just a part time gig. An hour or 2 of work in the afternoon (20-40 small parts). Live in Louisiana so humidity is a big problem I will have to deal with. What should I use to dry the air? A/C in the shop may be a option (I would not have a probelm with this, lol)
#13 (permalink) | ||
Yukon Gear and Axle
Member # 35700
That said, IMO it's probably too small for plasma work. You don't have 1 a large motor or 2 large tank, so the thing will be running constantly while cutting. According to the specs it should just keep up... Quote:
#14 (permalink) | |
Member # 20099
You can get that same compressor in blue or red at Lowe's/Home Deport for about $500.
Mine is a "Husky" and it's worked fine for my plasma cutter, though I don't have a CNC table. I have the compressor in my shed about 100ft from the garage. I ran 3/4" line underground from compressor to garage where I have it going into a ~30 gal oilless compressor (using just for the tank). I run the compressor at 150psi and regulate down to 120psi at the tank in the garage. Quote:
#15 (permalink) |
Member # 10
I had a similar compressor, 60 gal Husky. I was completely happy with it for running air tools and a handheld plasma, but as soon as I got the CNC table hooked up it was obvious it wasn't going to cut it. It would run continuously, and I even had to pause the program every so often to let the thing catch up.
I now have a 2-stage IR 60gal. In comparison to the running-continuously single-stage 60gal, it runs for about 1.5 minutes for every 3 or 4 minutes of cutting. (and I have the pressure set lower than normal right now)
Carl Whitmore |
#16 (permalink) |
Member # 194708
That helps me a lot. I'll probably go with the bigger 5hp 80 gal 16 cfm single stage from Lowes for 799 for now. Cheapest price I could find with those specs. Wasn't counting on having to get a air compressor so it puts me a little over budget. Guess I should have held off on the AVHC. Oh well, first job better be a big one or I'm be sleeping in the shop on the water table, lol.
Thanks Jason |
#17 (permalink) | |
Member # 3310
#19 (permalink) |
Member # 194708
The one from Lowers has been discontinued and is no longer available.
Will have to go with the Harbor Freight U.S. General 5hp 2 stage for $799. Although the U.S. General 3.5hp is tempting to try for $449. Same size tank and almost the same cfm. Can't find the auto drain on their site anymore. Jason |
#20 (permalink) | |
Member # 10
Carl Whitmore |
#21 (permalink) | |
Member # 185144
#25 (permalink) |
Member # 194708
I found this also that looks nice. $140 . All in one. Not sure the CFM but should be above 20 if used with a spray gun. Anyone try it?
