Suggestions For Bed Lights - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-16-2011, 03:39 PM   #1 (permalink)
D45
D45's Avatar
Member # 102974
I have an 8' bed on my truck, with a camper top
The interior light that came with the cap is not hardwired, but is rather battery powered, and it about useless!!!
I want a nice bright light, that I can turn on an off, as needed when I am camping and hunting.
Is a clear LED multi-bulb light the way to go?
What is the easiest way to wire up a light?
I know they make bed rail light kits.........but will they light up the bed enough, compared to mounting an overhead LED light where the current battery powered light is at?
http://www.gorecon.com/products.php?...2FCargo+Lights
http://www.gorecon.com/product.php?p...ht-Kit&p_cat=8
'04 QC/LB, 4WD, 305/555 HO CTD, 37x13.50 Toyo MTs on BMF Sota 8, 6" Lift, MBRP 5", IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special Turbo, SMARTY SR POD, ARP Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Built 48RE, Bullet Proof Steering
D45 is offline   Reply With Quote
Old 08-16-2011, 04:15 PM   #2 (permalink)
Dana 44 Polisher
Member # 13731
I have LED lights in my camper and they pretty much kick butt.
Do not get the chincy ones that are tail light replacement bulbs, get real rv/camper lights.
uglyscout is offline   Reply With Quote
Old 08-16-2011, 07:08 PM   #3 (permalink)
D45
D45's Avatar
Member # 102974
Would it be better to have a switch in the cab or near the light in the bed?
Old 08-16-2011, 08:19 PM   #4 (permalink)
Member # 130483
goto a RV shop and get a light to mount up high at the back
run 14g wire through a fuse to the back and use a 2pin trailer hitch plug (cut a 4pin in half if you cant find a 2pin)
wire up a universal cigar/accessory plug (optional and fukn handy) and the light
92 S10,sm465/np208/np241,d44,9inch,spools,exo
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote
Old 08-16-2011, 08:21 PM   #5 (permalink)
Member # 130483
as or the switch keep it in the back and most lights have them on the light
Old 08-17-2011, 06:31 AM   #6 (permalink)
D45
D45's Avatar
Member # 102974
If I could get away with just a single LED light, that would be great
How large of an LED light or how many LED bulbs would be needed for a bed space area?
Old 08-17-2011, 08:55 AM   #7 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
http://www.oznium.com/high-intensity-led-floodlight
MT4Runner is offline   Reply With Quote
Old 08-17-2011, 11:39 AM   #8 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
A good friend of mine told me he was going to put a pair of harbor freight fog lights inside the bed of his 8' camper shell. I was skeptical, then blown away how well they worked.
http://www.harborfreight.com/blue-gl...hts-46908.html
Great $13 solution.
GRMhick is offline   Reply With Quote
Old 08-17-2011, 01:59 PM   #9 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
Originally Posted by MT4Runner View Post
These are great lights. I run them for rock lights but next time I order something from them I'm going to order one or two for my camper shell and one for under my hood.
ErikB is offline   Reply With Quote
Old 08-17-2011, 11:18 PM   #10 (permalink)
D45
D45's Avatar
Member # 102974
Thanks for the link......looks like one light should have some good power for a closed space in my truck's bed
Old 08-18-2011, 02:18 PM   #11 (permalink)
D45
D45's Avatar
Member # 102974
I found some nice interior light kits that have a built in light switch on the light housing.........
http://cgi.ebay.com/ebaymotors/_W0QQ...KQ3aMEWAXQ3aIT
Old 08-20-2011, 11:48 AM   #12 (permalink)
D45
D45's Avatar
Member # 102974
I am definately going to get a 2 hole or 3 hole outlet strip
Is wiring it as easy as I think: Run two wires from the battery straight back to the outlet strip, making sure there is an inline fuse?
Since the LED light power draw is low, I could just tap off of the wires for the power strip, correct?
Old 08-20-2011, 04:41 PM   #13 (permalink)
D45
D45's Avatar
Member # 102974
I found three lights that come with built in switches..but what size and how many LEDs will I need?
1) 4-1/4" x 7", which has 38 LED's
or
2) 3.6" x 14", which has 50 LED's
or
3) 12" x 4-1/4", which is a dual set of 38 LEDs per side, 76 total
Old 09-07-2011, 03:47 PM   #14 (permalink)
D45
D45's Avatar
Member # 102974
http://www.galls.com/google/style-SE...ole-outlet-box
I just bought this outlet box, it is nice because of the power switch and the plug covers
Old 09-25-2011, 04:27 PM   #15 (permalink)
D45
D45's Avatar
Member # 102974
Ok guys, what is going to best method to mount a light?
I bought a 76 LED light, that is about 4" x 14" long
I am going to run the light long-wise, kind of parallel with the length of the bed
I was going to drill two mounting holes in the fiberglass cap and just seal the mounting bolts with 3M 5200 Marine Grade Sealant
However, I would rather not have two holes in the cap.....is there any product out there that will hold a light securely to the fiberglass and not less go....or dry out, etc?
Liquid Nails?
Old 09-25-2011, 04:47 PM   #16 (permalink)
takotruckin's Avatar
Member # 106178
It may be overkill, but for stuff like that I use 3M panel bonding adhesive. Its the shit that they glue cars together with, most bedsides, quarter panels etc.
takotruckin is offline   Reply With Quote
Old 09-25-2011, 05:48 PM   #17 (permalink)
D45
D45's Avatar
Member # 102974
Thanks, I will look into the panel bonding adhesive
The light fixture itself is rather lightweight, just want to make sure bumps and potholes do not jar the fixture loose
Old 09-25-2011, 06:12 PM   #18 (permalink)
coyote's Avatar
Member # 170
I used tack studs and cemet...
Red Racer I
Toyota FJ62
coyote is offline   Reply With Quote
Old 09-25-2011, 10:17 PM   #19 (permalink)
Coke dealer...
7.62FMJ's Avatar
Member # 66780
3M two-sided adhesive tape. I installed the ballasts for my HID with this tape under the hood of my Ram. I misplaced one of the ballasts and tried to pull it off...and HOLY SHIT does that stuff stick! I really thought I was going to pull the back off of the metal ballast...
Awwww Piss!
7.62FMJ is offline   Reply With Quote
Old 09-26-2011, 07:33 AM   #20 (permalink)
Member # 150595
A good place to shop for LED's.
The category you need to look in.
http://www.superbrightleds.com/cgi-b...bes.htm%23alms
http://www.superbrightleds.com/cgi-b...xart_specs.htm
Nat
Nat_sters Haul All [url]http://www.pirate4x4.com/forum/showthread.php?t=1004576[/url]
nat_ster is offline   Reply With Quote
Old 09-28-2011, 02:16 PM   #21 (permalink)
D45
D45's Avatar
Member # 102974
Here are some pics:
-3" x 14" Housing Size
-100,000 Hour Rated LED Life
-3 Position On/Off Switch
-12 Volt DC power
-120 Lumen Light output
-Three Wire Connection, 7" leads
-50 LED's
Old 09-28-2011, 03:47 PM   #22 (permalink)
Quit looking
Belooky's Avatar
Member # 138061
I would just use 5200 sealant. Its what is used in marine applications and the shit is hard to get off. It will hold just fine
Altman's Racing
1996 f250 D60, 10.25, 557bbf, bottle fed by giggle gas
Belooky is offline   Reply With Quote
Old 09-28-2011, 06:27 PM   #23 (permalink)
D45
D45's Avatar
Member # 102974
Use 5200 to hold the light in place or 5200 to seal the mounting holes?
Old 09-28-2011, 08:25 PM   #24 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
I think you're over thinking it. It isn't like you're going to be replacing the LEDS. Doesn't look like the housing even opens up (maybe it does). But I'd just glue the thing to your cap and be done with it - epoxy, silicone, whatever.
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 10-19-2011, 04:03 PM   #25 (permalink)
D45
D45's Avatar
Member # 102974
I weighed the LED light housing an it is around 8.50 ounces, next to nothing
I think a good epoxy will hold the LED housing secure to the roof top
My Gall's 3 Hole 12V Outlet Box also came and it is really nice, well built with a nice on/off switch. It also has its own inline fuse:
Galls 3-Hole Outlet Box - SE090
