only have 4th gear in my getrag tranny. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2011, 10:21 AM   #1 (permalink)
Member # 190967
so i was driving my 93 cummins down the road and i heard a grind in 5th gear i shifted down to 4th and went back into 5th and no gear drove the rest of the way home in 4th. when i got home i found out there was no gaers other then 4th. is this an easy fix or is the tranny toast?
Jimbert78bronco is offline   Reply With Quote Quick reply to this message
Old 10-15-2011, 10:55 AM   #2 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
Probably toast. Sounds like the counter shaft took a total shit. Fourth gear would be the only range that does not route through the counter shaft. It simply connectes the input shaft directly to the main shaft.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote Quick reply to this message
Old 10-15-2011, 02:01 PM   #3 (permalink)
woodchuck2's Avatar
Member # 116651
Yup, too late to fill it full of sawdust and send it down the road. Think new or rebuild.
79 F-150 302,np435, rest of the truck has been sold and is now retired.
woodchuck2 is offline   Reply With Quote Quick reply to this message
Old 10-15-2011, 04:58 PM   #4 (permalink)
alex211's Avatar
Member # 142183
http://www.dieseltruckresource.com/d...0-t296210.html
Shitbox xj 5 speed on 33s
alex211 is offline   Reply With Quote Quick reply to this message
Old 10-15-2011, 09:45 PM   #5 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
could have just sheared the roll pins in the shift rails. common on getrag 360's, i've fixed alot by pulling the top cover off and replacing them with better ones.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is online now   Reply With Quote Quick reply to this message
Old 10-16-2011, 03:02 PM   #6 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The hearing a grind part sounds familiar, both times I`ve had this happen the bearings between the input shaft and main shaft seized, essentially locking the transmission in 4th. Push it a little farther and it`ll blow up the 4th gear syncro and give you everything but 4th again, but, take it apart now and see what is happening.
I really hope your truck has had the trans tunnel cut for transmission access... Makes life much easier.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 05-14-2012, 02:05 PM   #7 (permalink)
Member # 218780
hoping for help!!
I am working on my G360 and found a sheared pin as you described on my 5-R fork. (Along with a bad reverse slider ring, the cause of the sheared pin) But i cannot find a supplier for the roll pins. Please let me know where you located the pins or any other info that might get me there. Thanks for your time, I really appreciate any help on this!!
1stgenstartagain is offline   Reply With Quote Quick reply to this message
Old 05-14-2012, 02:31 PM   #8 (permalink)
Member # 192237
Measure your pin
Go to hardware store
Go to a real hardware store
Pay out the ass
You'll get your part for under $2
Old 09-16-2013, 07:33 PM   #9 (permalink)
Member # 42036
This happened to me, and the truck is ~400mi from home at my buddy's house. Can't stay there forever (see thread) and so I'm wondering if I could just drive it home in 4th the whole way?
Then it could sit at my house and I could part it out, look for a tranny at my leisure, etc ... have options at least vs. just trying to firesale it.
Kirkor is offline   Reply With Quote Quick reply to this message
Old 09-17-2013, 06:07 AM   #10 (permalink)
Member # 82908
You have a getrag in your nissan?
cgwfab is offline   Reply With Quote Quick reply to this message
Old 09-17-2013, 07:57 AM   #11 (permalink)
Member # 42036
No, but the "only having 4th gear" problem occurs when stuff breaks in a variety of transmissions from what I've read ... something about 4th being direct to the transfer case, other gears are off the lay shaft/inner shaft.
I've already driven it 20 miles or so like this, from the road to the mechanik, to one bud's house, then back to another bud's house.
Drives fine in 4th, of course I have to ride the clutch quite a bit from stoplights.
