DCD: Dirt Cheap Deckover - Page 20 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2012, 03:19 PM   #476 (permalink)
Back Woods's Avatar
Member # 74825
Ready to put the axle in. I was going to put disk brakes in the rear, almost everything to do it. Got lazy and didnt want to buy any more parts so I left the drums. They have fresh parts in them so it will be fine until I want to change them.
Just some rollers on it.
Back Woods is offline   Reply With Quote
Old 05-14-2012, 04:22 PM   #477 (permalink)
Back Woods's Avatar
Member # 74825
Getting somewhere now.
Old 05-14-2012, 04:54 PM   #478 (permalink)
Member # 154867
The wheel chocks show that you're truly dedicated to safety. Hope it goes well, I'm excited for the fenders.
OHV Wildcat is offline   Reply With Quote
Old 05-14-2012, 06:49 PM   #479 (permalink)
Back Woods's Avatar
Member # 74825
They are full chocked now. Chocked the back when I pulled the shaft etc. Didnt realize I would have to pick it up so high, did front.
Old 05-14-2012, 08:06 PM   #480 (permalink)
Back Woods's Avatar
Member # 74825
Got one leaf pack built. Used the spacer for the OEM helper spring, and cut the overload down so it is just a spacer. I bought 1/2 center bolts and stock is 7/16. I decided to drill out all of the center bolt holes, getting good at sharpening bits. Probably going to burn through 2 bits drilling out all the springs.
My camera cant focus worth a damn at night.
Old 05-15-2012, 05:46 AM   #481 (permalink)
Member # 212466
Originally Posted by Harold Phipps View Post
I think we need to see it being held up by topless girlfriend.
Make sure she is standing in front of a running (on max cold, high fan) air conditioner.
If you're that fucking desperate to see a topless woman then go google some porn sites.
Find the right ones and you'll get to see a lot more than just tits!!!
Proudly supporting Black Jewish Gays since 2005.
DasLandRoverMan is offline   Reply With Quote
Old 05-15-2012, 05:56 AM   #482 (permalink)
Bones's Avatar
Member # 3007
Bones is offline   Reply With Quote
Old 05-15-2012, 01:53 PM   #483 (permalink)
BassnTruck's Avatar
Member # 86582
STFU noob. Stop shitting up this shittastic thread.
BassnTruck is offline   Reply With Quote
Old 05-15-2012, 03:12 PM   #484 (permalink)
Back Woods's Avatar
Member # 74825
Queers.
Axle should be in tomorrow. Got to take a break tonight, the lady got a new car.
Old 05-16-2012, 12:10 AM   #485 (permalink)
Member # 212466
You seem a nice friendly chap. A real kind and fluffy personality I'd say.
So what's the new motor Mr Woods? Company car from the Merc dealer, or something a little more sedate?
Old 05-16-2012, 03:36 AM   #486 (permalink)
Back Woods's Avatar
Member # 74825
2007 SEL Taurus
Yea Ford.
Old 05-16-2012, 09:54 AM   #487 (permalink)
Member # 130003
What is the spacer in the middle of the spring pack for?
Ever seen humor before dasroverman?
No go fuck yourself.
Harold Phipps is offline   Reply With Quote
Old 05-16-2012, 10:01 AM   #488 (permalink)
Back Woods's Avatar
Member # 74825
Took it out, looks better.
Old 05-16-2012, 11:45 AM   #489 (permalink)
Member # 212466
Obviously more than you have if you're taking it that seriously.
Ever heard of a spelling/grammar check?
Old 05-16-2012, 12:29 PM   #490 (permalink)
Back Woods's Avatar
Member # 74825
Ever heard of shut the fuck up?
Old 05-16-2012, 01:59 PM   #491 (permalink)
Member # 212466
Yup, guess you have too?
Finished your axle swop yet?
Old 05-16-2012, 02:49 PM   #492 (permalink)
bf
TANK
Member # 131367
DasLandRoverMan
Is this really what you want to come back with in this situation? There are quite a few incomplete sentences and misspellings in what you are saying.
Sincerely,
The spelling and grammar police.
Originally Posted by GONRACIN
it's far better to have more truck then you need, than to need more truck then you have....
bf is offline   Reply With Quote
Old 05-16-2012, 04:31 PM   #493 (permalink)
Member # 143307
Originally Posted by bf View Post
DasLandRoverMan
Sincerely,
This.
ToughBowtieTruck is offline   Reply With Quote
Old 05-16-2012, 04:50 PM   #494 (permalink)
370
Member # 153116
Originally Posted by Dustin Smith View Post
The trailer is a vehicle. That FMCSA rule is stating if the towed vehicle (trailer) is over 10k, it is in effect.
i think you need to reread that part of the law. it says you have to be over 26001 lbs and the trailer must be over 10k. since he'll be under the 26001lb wieght limit he's fine. otherwise every old couple with a F350 and a 5th wheel camper would need a class A cert.
370 is offline   Reply With Quote
Old 05-16-2012, 06:57 PM   #495 (permalink)
Back Woods's Avatar
Member # 74825
Finished both leaf packs today. When I got my U-bolts bent I got them longer than stock thinking there would be plenty of thread. Wrong, had to order a $40 5/8-18 die to thread them deaper.
Difference between the 10.25 and 10.5 yokes.
Super duty is on bottom, they swapped no problem.
Made a new breather also, put it right over the ring. Get that heat out!
Old 05-16-2012, 07:07 PM   #496 (permalink)
Member # 99723
You know there is a reason that the breather is not there from the factory right?
Moore87 is offline   Reply With Quote
Old 05-16-2012, 07:37 PM   #497 (permalink)
Back Woods's Avatar
Member # 74825
blowing fluid up and out the tube?
Ill make the vent 6ft long so it can never reach the end.
Old 05-17-2012, 12:20 AM   #498 (permalink)
Member # 212466
You do know breathers arn't for cooling?
They're there to allow for expansion and contraction of air and fluids within the axle tube so it doesn't end up blowing the seals out.
Old 05-17-2012, 03:35 AM   #499 (permalink)
Back Woods's Avatar
Member # 74825
So besides it pushing oil out whats the difference of it being in the tube or in the cover? When I took apart the SD axle its breather was completely plugged.
Is the air/fluid expansion not caused by heat?
Old 05-17-2012, 05:42 AM   #500 (permalink)
Member # 212466
Yes, as the diff works it warms up the oil, which will expand to a degree, along with the air in the axle.
The diff and bearings are splash lubricated by the oil (as opposed to a pressurised lubrication system as with engines and some gearboxes) which also assists with keeping things cool, along with a heat sink effect from the axle casing means with the right oil at the correct level they won't purposefully overheat.
As the axle isn't designed to be under pressure, neither are the seals in the hubs and diff pinion, hence the need for the breather, to allow the air to move as things warm up/cool down, and also why you get leaky seals when breathers get blocked.
Your breather will work as is, and quite possibly work well as a temp gauge for the back axle, but otherwise offers no real benefit.
