Home built trailer Design Q? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2012, 10:33 AM   #1 (permalink)
Gettin there!
rockbuggy84's Avatar
Member # 45202
So after hours and hours of searching and stopping to measure numerous trailers, I still dont have an answer. I want to build a light 24' 2 rig hauler. My idea is to use 2 x 6 x 3/16 as the main frame.
I will build a 24' x 6.5' perimeter with the 2 x 6 tubing and install 2 x 2 x 1/8 tubing cross supports every 16". I will then install 2x8 wood studs for the deck. So my question is if this sounds strong enough to haul 2 CJs on tons.
I was thinking that if the first jeep was loaded backward and 2nd forward, this would put the main weight of them (engine etc) more or less over the axles. This would reduce them trying to flex the trailer between the hitch and trailer axle.
I have seen quite a few heavy duty equipment trailers that use 6" I beam and that is the only design difference vs mine and understand its stronger. But I dont plan on hauling anywhere near what those trailers are rated for.
Wheeling before all the dbags made it "trendy"
rockbuggy84 is online now   Reply With Quote
Old 02-18-2012, 08:42 PM   #2 (permalink)
Member # 7938
Sounds good to me.
KS Toy is offline   Reply With Quote
Old 02-18-2012, 10:44 PM   #3 (permalink)
SixSped5's Avatar
Member # 126806
Send a message via AIM to SixSped5
2x6/2x2 what? Angle? Channel? Tubing? I'm assuming tubing.
I have seen very few trailers with 6" I-Beam (Usually larger), there are a lot of 6" channel trailers out there though. I will do some research, but I am afraid I am not qualified to compare Channel or I-Beam to the strength of tubing.
Jack Miles :: Tampa, Florida ::
2003 Dodge Ram 3500 - QC/DRW - 4x4/SixSpeed - Tow Rig
1978 Mercedes L1116 4x4 - 6CTA Cummins - Hiab 550 Knuckle Boom
1963 Unimog 404 / Doka Hardcab / TurboDiesel / Exocaged / NotMuchStock - Play Rig
1961 Unimog 404 / Soft Top / Flat Bed
SixSped5 is online now   Reply With Quote
Old 02-19-2012, 06:22 AM   #4 (permalink)
Member # 78077
Thats what we need to know to help.
Don't blame me, I voted against him.
#rawkon is offline   Reply With Quote
Old 02-19-2012, 06:38 AM   #5 (permalink)
Member # 196490
There are quite a few trailers out here that people have built from tearing down junked travel trailers if that's an option for you. They abuse...err use them to haul scrapped cars and so far look to be holding up okay.
My IDIot Build [url]http://www.pirate4x4.com/forum/showthread.php?p=14157134[/url]
Bustin Loose is offline   Reply With Quote
Old 02-19-2012, 12:38 PM   #6 (permalink)
Gettin there!
Member # 45202
Tubing, sorry didnt post prior.
Old 02-19-2012, 01:27 PM   #7 (permalink)
Member # 78077
I wouldnt try it with tubing. go with channel.
Old 02-20-2012, 08:32 AM   #8 (permalink)
Member # 82644
Why? Wouldn't 2x6x3/16 rectangular tubing be stronger than 2x6x1/4 channel? Just wondering as I've been thinking of redoing my trailer. Make it 26' with 2x4.3/16 rectangular. I just don't know if it'll be strong enough.
[QUOTE=xjdoug;9487015]this is like watching a kid stick his finger in a light socket.... sooner or later he's gonna figure out why the rest of us arent doin it...[/QUOTE]
hadfield4wd is offline   Reply With Quote
Old 02-20-2012, 12:14 PM   #9 (permalink)
Gettin there!
Member # 45202
This has been my question? I see alot made of C channel but is it really that much stronger? I think 2x4 3/16 would be pushin it at 26' for a car hauler but not sure?
Old 02-20-2012, 12:51 PM   #10 (permalink)
$5 Fine For Whinin'
pic_jon's Avatar
Member # 142381
FWIW... BigTex uses 12" I beam for the frame & neck (with 3" channel cross-members) of their 14k Rated 102" x 20+5 Gooseneck. It weighs in at 4920#.
http://bigtextrailers.com/pdf/product.pdf
If I were to use tubing, it would probably be galvanized simply because it's hard to paint the inside of tubing...
Project "Lacking Time"
pic_jon is offline   Reply With Quote
Old 02-20-2012, 01:08 PM   #11 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Biggest concern is hidden rust/corrosion.
Not only is it hidden, but it's more likely. You WILL get water inside the channel, and once inside, it will take quite a long time to dry.
Agreed. My boat trailer is galv. tubing (as are a lot of boat trailers).
MT4Runner is offline   Reply With Quote
Old 02-20-2012, 02:26 PM   #12 (permalink)
Gettin there!
Member # 45202
Way overbuilt and not even close too lightweight
Not even close to a problem around here
Lets throw the rust, I beam, c channel issues out the window. Is the design strong enough for said purpose?
Old 02-20-2012, 02:41 PM   #13 (permalink)
Expert Web Wheeler
ryantowry_81's Avatar
Member # 122722
this is about the closest build i have seen as to what you are trying to build:
http://www.kaufmantrailers.com/heavy...ailer-p67.html
it is slightly longer but weight wise would be similar, looks like they have 4 6" C channels for a deck and a 6" C channel tounge all the way to the axles.
If you did 6" touge to the axles with the 6" c chanel deck on top with a 4" C channel stringer in a 25ish length i bet you would be structually sound.
just my 2 cents though.
ryantowry_81 is offline   Reply With Quote
Old 02-20-2012, 03:00 PM   #14 (permalink)
Landman87's Avatar
Member # 192722
Sounds like it should work. My heavier equipment trailer have 6" channel on them then the tongue is 6" also that runs all the way back to the axles. Its only a 20 footer also. I'll grab a pic for you real quick. I think where your going to run into your issue is being that long its going to want to torque pretty bad. Here's the pic for reference
Landman87 is offline   Reply With Quote
Old 02-21-2012, 07:49 AM   #15 (permalink)
Member # 82644
Well I hope I'm not hijacking too much. If I could go to 4" I could drop my trailer 6". What I would do would be 4" box, but I suppose I could to channel as long as it was strong enough due to the rust issue. I would then have extensions about 10" width wise to make the trailer wider and drive over fenders. This would be doen with 2"x2" or even 2" channel. with a "hump" for the fender area. This would add strength for the entire length. Then wood in the middle. I don't mind the tube much as my flatbed is all of tube. Rust can't be that big of a deal.
Like this one.
6" is alot to drop my trailer. Going from deck over this will reduce my frontal windage.
Old 02-24-2012, 06:23 AM   #16 (permalink)
Member # 82644
anybody?
